Exhaust Manifold for Universal M-25XP - SailNet Community
post #1 of 16 Old 03-03-2011 Thread Starter
Jim.Stevens
Does anyone know of a source for used Universal diesel parts. I need an exhaust manifold for an XP25. Thanks
jpscontractor is offline
post #2 of 16 Old 03-03-2011
JimsCAL's Avatar
Universal diesels are actually Japanese Kubota industrial engines. You may be able to get parts from a Kubota dealer at a fraction of the cost from Westerbeke/Universal. Do a little research to find out the Kubota engine model number.
JimsCAL is offline
post #3 of 16 Old 03-03-2011
the pointy end is the bow
erps's Avatar
do you need the whole manifold, or the just the injection elbow? A metal fabricator could probably fix you up with a new injection elbow.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #4 of 16 Old 03-03-2011 Thread Starter
Jim.Stevens
Unfortunately the Kubota engine breakdowns I've seen have a different manifold for tractor use.
post #5 of 16 Old 03-03-2011 Thread Starter
Jim.Stevens
Unfortunately it looks like I have a crack in the manifold itself.
post #6 of 16 Old 03-04-2011
JPS,
It is correct that the Universal M25XPB is a Kubota and you can get many of the parts from Kubota. However the part that you need the exhaust manifold is part of the 'marinisation' done by Universal. In the tractor engine they use a radiator instead of our heat exchanger hence the exhaust manifold is quite different. Net-net you will need to get the manifold from Universal or get a used one from somewhere.
Sorry, if this was not the news you were expecting. Post of you have any other questions. Cheers.
SeaFever2000 is offline
post #7 of 16 Old 03-04-2011
JimsCAL's Avatar
New manifold is $1548 (!!) on marinedieseldirect.com.
JimsCAL is offline
post #8 of 16 Old 03-04-2011
jjablonowski's Avatar
JB Weld?
jjablonowski is offline
post #9 of 16 Old 03-04-2011
JPS,
Unless you want to get the part from Universal, I think, the best thing would be to take the manifold to a radiator shop/workshop have them pressure test it and weld the crack. They will clean it before they weld it and they will go a good job. A metal welding will be much more reliable than anything like JB Weld.
My two cents...
post #10 of 16 Old 03-05-2011 Thread Starter
Jim.Stevens
Originally Posted by SeaFever2000 View Post
JPS,
My two cents...
Thanks, that looks like the most cost effective solution. I deal with some very good shops here in Dallas.
Oil for M-25XP Universal chuck53 Diesel 2 10-10-2010 12:52 PM
replacing our Universal 25XP inshallamiami Diesel 7 02-15-2010 04:59 PM
need exhaust manifold for my W30 captaineasy Gear & Maintenance 0 10-06-2009 05:08 PM
Need W 30 exhaust manifold captaineasy Diesel 0 10-06-2009 03:47 PM
MD11C Exhaust Manifold takwita Gear & Maintenance 1 11-10-2004 01:35 PM
