Yanmar spares kit good idea? - SailNet Community
post #1 of 10 Old 03-22-2011 Thread Starter
batkins61's Avatar
Are pre-assembled spares kits, like this one: https://www.pyacht.com/cgi-bin/pageg...20f3gm30f.html, a good idea, or are you getting stuff you don't need and/or paying a premium over individual parts? Or, is it missing important items you'll need for repairs underway?
We definitely want to have engine spares on board (it's a 3GM30F), but we're not sure whether this is the best option.
Where's a good place to get either the kit, or individual items?
Thanks!
batkins61 is offline
post #2 of 10 Old 03-22-2011
Crealock 37
sailak's Avatar
Dock
Some would depend on the type sailing you do. Long trips away from port? or just weekend stuff.
Zincs and oil filters are scheduled maintenance stuff - I don't drag them around with me.
Impeller, gaskets, screws or other items I might need to make a quick repair I certainly have on the boat at all times.
In my experience pre-made kits tend to be handiest for putting money in the cash register -- you would probably be better off deciding what YOU need as spares and making up your own kit.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #3 of 10 Old 03-22-2011
Gary M's Avatar
It looks to me like you need all of those items so just compare costs to buy individually but that does not look like a bad price.
Another good on line source is Torresen Marine.
Gary
Gary M is offline
post #4 of 10 Old 03-22-2011 Thread Starter
batkins61's Avatar
Well, we need to move the boat from South Carolina to North Carolina, but after that, mostly cruising the NC sounds with jaunts to Cape Lookout, etc.
I've never owned or messed with a Yanmar or any diesel for that matter, so I'm not sure what would be needed (other than what's listed in the kits). I've worked on other motors (cars, Yammie 150 OB, etc.), so I'm pretty sure I can get to know may way around relatively quickly, but I'm still in the bootstrap mode.
Are there manual options (like Haynes for cars, etc.)? A good source?
TY!
post #5 of 10 Old 03-22-2011
Pearson 303
SVCarolena's Avatar
I think the kits tend to have more than you need, especially if you are not going offshore for long periods of time where you need to be completely self-sufficient. When it comes to maintenance items like water pump impellers, for instance, we replace every year and then keep the old one as a spare in case of an emergency. I strongly suggest that you get the Yanmar manuals. I have both the parts and service manuals and use them all the time. I bought aftermarket manuals right after we bought the boat, thinking I'd save some money, and now they just sit on the shelf. Instead of the aftermarket manuals, get a book like Calder's Boatowner's Mechanical & Electrical Manual and it will cover everything in the aftermarket manuals plus A LOT more. That and the factory manuals will have you covered from stem to stern.
EDIT - I just looked at that kit and it is pretty much just a seasonal maintenance kit. I'd also suggest getting Gates GreenStripe belts instead of the Yanmar belts (made by Mitsubishi). The Gates belts are much better quality and won't shed dust like the Yanmar ones do. Aftermarket oil filters should also be fine (although I personally get the Yanmar ones just because of convenience). The air filter element just needs to be cleaned each year, not replaced.
SVCarolena is offline
post #6 of 10 Old 03-22-2011 Thread Starter
batkins61's Avatar
What's a good source for the Yanmar manuals and Gates belts?
post #7 of 10 Old 03-23-2011
Seems like they left out a bunch of stuff if your going for a long cruise. Engine cooling hoses and gaskets. I would make up your own. Oil filters and fuel filters oil belts and Impellers. You need maint parts if your goint to be ON a long cruise were you will run more than 100 hours (winter in Bahamas) You dont want to pay the customs charges for parts you didnt bring. But that kit seems like its not enough. IMHO
P424 is offline
post #8 of 10 Old 03-23-2011
With any kind of RUBBER spare parts, it is a good idea to dust them with talc (plain talcum powder, not scented, not cornstarch) and then seal them up in heavy plastic, to prevent oxidixation. The rubber parts supposedly have a life of just 5 years, used or not used, and preventing oxidation extends that. the talc seals the surface, without affecting anything else.
hellosailor is offline
post #9 of 10 Old 03-24-2011
Pearson 303
SVCarolena's Avatar
Manuals I've ordered online through Torrensen Marine (although whether they can ship to you depends on your location as Yanmar enforces defined sales and distribution areas). The belts I ordered through Amazon after I found the right ones on the Gates website.
post #10 of 10 Old 04-07-2011
If this is your first time with this boat, I would suggest you replace all filters, fuel and oil. If the fuel tanks are low, drain and refill them.Change oil Change the impeller. bring extra impeller and several fuel filters. Newly aquired boats often have fuel problrms. Its easer to replace now than in the sound.
Highly suggest you get towing insurance, west marine is one, see who handles your area.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
badsanta is offline
in a storm... good or bad idea to... jobi Learning to Sail 14 07-05-2010 04:58 PM
Who thought this was a good idea? flyingwelshman General Discussion (sailing related) 14 04-08-2010 07:19 AM
Good idea or not: Downhaul for hank-on jib jgsteven Gear & Maintenance 19 07-04-2009 06:52 AM
yanmar motor mount replacement idea scottyt Gear & Maintenance 30 02-06-2009 09:18 AM
a good food idea Tegolin Provisioning 1 06-25-2005 07:47 PM
