yanmar 2qm15 fuel problems - SailNet Community
post #1 of 7 Old 04-01-2011 Thread Starter
I have a 2qm15 which had gotten water in the tank several times before I figured out what was going on. I cleaned the tank, lines, replaced filters and it ran fine for awhile. Now it is difficult to start when cold, dumps raw fuel out the exhaust with black and white smoke, then mostly clears up, and will power up in or out of gear to almost full power. However, when I throttle back, then up again, it belches raw fuel, black and white smoke. I pulled the exhaust elbow and found the smaller line coming from the cylinder head into the elbow almost blocked. Cleaned it out and replaced the elbow, but still has raw fuel, black and white smoke out of the exhaust. I haven't tried injector cleaner yet. Is that a good next step, or any other suggestions?
pfirth is offline
post #2 of 7 Old 04-01-2011
If you have been running with water in the fuel it is a big risk that your injector nozzles needs to be replaced.
Pull the injectors and send to a shop.
haffiman37 is offline
post #3 of 7 Old 04-01-2011 Thread Starter
fresh water
Thanks Haffiman 37. The water that got in the engine was all fresh. Do you think I could try an injector cleaner first, and are some brands better?
pfirth is offline
post #4 of 7 Old 04-01-2011
Fresh or salt in the injectors does not matter that much.
Most likely if taking the injectors apart, you will find that the needle in the nozzle has 'blued' out, and when pressure testing the injectors 'drips'.
Injector 'cleaners' may clean for carbon build-up, but not this problem.
post #5 of 7 Old 04-01-2011
Courtney the Dancer
jrd22's Avatar
Haffiman is 100% right. You need new tips on the injectors.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #6 of 7 Old 04-01-2011 Thread Starter
Thank you guys. I will post results and send you messages of the outcome.
pfirth is offline
post #7 of 7 Old 04-01-2011
RichH's Avatar
Remove the injectors and send/take them to a local 'injector shop'. Every town over 10000 pop. usually has one. Most times such injectors can be remedied and/or 'rebuilt'.
RichH is online now
Yanmar fuel/ power problems snowdawg Diesel 13 12-04-2013 11:22 PM
Yanmar SB12 Fuel Pump Problems hshannon Gear & Maintenance 8 07-27-2010 09:40 AM
Yanmar 2QM15 fuel consumption? 30Irwin Diesel 9 09-04-2009 11:17 PM
Yanmar 2QM15 - Changing the Fuel Filter backcreeksailor Gear & Maintenance 15 06-04-2009 07:36 PM
Yanmar 2QM15 Bleeding Fuel System - HELP shipley Gear & Maintenance 5 03-11-2002 07:21 PM
