Banjo bolt and washers needed - SailNet Community
post #1 of 3 Old 04-15-2011 Thread Starter
skipgundlach's Avatar
On a Perkins 4-154, one of my lines to the injectors from the pressure pump has a very slight leak.
So far, I have not been able to identify a part number to obtain a spare banjo bolt, much less the washers. Finding aluminum washers is very challenging.
Anybody have a PN (and, better yet, a source? - TAD couldn't come up with one, and the parts manual doesn't have a PN for it, either, despite having a part number for each and every other bolt and nut and washer for this engine) for a BB and washers for this beast?
Thanks.
L8R
Skip
Morgan 461 #2
SV Flying Pig KI4MPC
See our galleries at
Follow us at
and/or
skipgundlach is offline
post #2 of 3 Old 04-16-2011
Midwest Puddle Pirate
US27inKS's Avatar
Have you checked with a local diesel engine repair shop? I would look for a shop that rebuilds injectors and pumps. You don't need someone who is a marine diesel guy, small truck diesels should have similar bolts and washers. They should carry a line of banjo bolts and washers. Also be aware that you can use copper washers for this. I've found copper washers at the local Ace hardware.
John USYacht 27 "Cora Lee"
US27inKS is offline
post #3 of 3 Old 04-16-2011
T37Chef's Avatar
What he said...a local injector should/would proabably have what you need....and you'll save some $$$
Shawn
T37Chef is offline
Pressure Washers TakeFive Gear & Maintenance 29 08-20-2011 11:36 PM
metric banjo fittings tgzzzz Diesel 2 05-22-2010 04:18 AM
Keel bolts & Mild Steel Washers scuppers S2 5 11-04-2008 01:00 AM
Banjo Bolt Stripped? T37Chef Gear & Maintenance 2 07-11-2008 12:03 AM
Annealing Copper Washers W.Ritchie Gear & Maintenance 1 08-31-2001 08:13 AM
