Volvo MD2040C sail w/engine in neutral? - SailNet Community
post #1 of 4 Old 04-19-2011 Thread Starter
I have just finished reading the Volvo manual on my MD2040C diesel and they state uncategorically that when sailing the transmission must be in neutral.
The prop and shaft spin quite a bit sailing like this, its noisy and annoying, and I suspect slows the boat down.
Anyone have any experience with this? Shaft-loc has been suggested to me but its quite expensive.
Has anyone sailed with their Volvo transmission in reverse to lock the prop? Any problems develop from that?
Any comments or ideas would be appreciated.
birdlives is offline
post #2 of 4 Old 04-19-2011
I can't address the noise (or wear) issue, but I've recently reversed my long held belief about drag based on this and other articles. http://www.catamaransite.com/propeller_drag_test.html
Islander 30 MKII "Sojourn"
shogan50 is offline
post #3 of 4 Old 04-19-2011
mitiempo's Avatar
A spinning prop will cause less drag than a fixed one. The reason for neutral, at least with a Yanmar is that the cone clutches wear and Yanmar has issued a warning about this. Volvo may have the same issue.
Yes, the noise can be annoying. A shaft brake of some kind is the solution.
Brian
mitiempo is offline
post #4 of 4 Old 04-20-2011
JimsCAL's Avatar
Or a folding prop. No spinning shaft and reduced drag when sailing.
JimsCAL is offline
Volvo engine l7leandro Catalina 0 01-19-2011 06:41 PM
Sail in Forward, Reverse, or Neutral? elcap373 Gear & Maintenance 15 01-25-2010 07:05 PM
Volvo Engine no power Dignity Diesel 7 06-15-2009 10:57 AM
Volvo Penta engine rondezvous Gear & Maintenance 1 09-24-2006 12:24 PM
volvo engine gto2 Gear & Maintenance 2 06-20-2002 08:46 AM
