Help with yanmar 2qm15 stuck transmission - SailNet Community
post #1 of 3 Old 05-04-2011 Thread Starter
I have a 1976 newport sailboat that I am restoring. I was away from the boat for about 6 months and now my transmission will not go into gear. It appears to be stuck on the inside of the gear box. The transmission lever will not move. The transmission was working fine before I went out of town. The sailboat has milky fluid in the box so water has somehow seeped in to the gear box but this might have happened when the transmission was partially submerged. Can anyone tell me what could be the possible causes or remedies. Thanks for any help!
Waterman28 is offline
post #2 of 3 Old 05-04-2011
Originally Posted by Waterman28 View Post
..... The transmission was working fine before I went out of town. The sailboat has milky fluid in the box so water has somehow seeped in to the gear box but this might have happened when the transmission was partially submerged..... .
Partially submerged? I suspect you've answered your own question. Sounds like a removal and replacement, certainly a teardown and rebuild if that's practical.
Faster is online now
post #3 of 3 Old 05-05-2011
Omatako's Avatar
Your next challenge is going to be getting the gearbox off the engine. I spent days on mine -the input shaft going into the flex plate on the flywheel rusts in nice and tight and is a real mother to get off.
If it comes to that and you need advice, PM me. Been there done that.
Arthur C. Clarke
Omatako is offline
Yanmar 2GM or 2QM15...? marinesniper Gear & Maintenance 20 03-10-2012 12:47 AM
Yanmar 2QM15 sundownersc Diesel 11 02-09-2012 09:21 AM
Yanmar 2QM15 repairtime Gear & Maintenance 7 12-09-2011 04:40 AM
2qm15 motor mounts and transmission alignment kegendron S2 2 03-08-2011 07:24 PM
Yanmar 2QM15 rpowell Gear & Maintenance 3 01-10-2002 08:26 PM
