Exhaust elbow help needed - SailNet Community
post #1 of 15 Old 05-05-2011 Thread Starter
My Westerbeke 30 exhaust elbow bit the dust. I was surprised and quite happy to order a seemingly exact replacement.....turns out it was made out of aluminum. As I researched it, this is not an acceptable material for diesel wet exhausts. However, the seller says he has "sold hundreds of these" and that it is no problem. Did I read the ABYC pfd incorrectly?
http://www.abycinc.org/committees/P-01.pdf
Anyone with experience in this? Anyone know where I can get one like this in a material from table 1?:
MMD MMD33067 90 Degree Exhaust Elbow, 1-1/2\" - Torresen Marine - The Sailboat Specialist
Gary
P.S. The dealer is NOT Torrensen, and I would prefer to leave them nameless as I have no prior experience with them. I used the Torrensen link because it has a color pic.
SantaAna12 is offline
post #2 of 15 Old 05-05-2011
Old as Dirt!
svHyLyte's Avatar
You might contact Transatlantic Diesel (TAD for perkins engines, perkins diesel, perkins marine, perkins parts, perkins generators, perkins service ). They deal in Perkins but I seem to recall they also handled Westerbeak.
svHyLyte is offline
post #3 of 15 Old 05-05-2011
My Beta came with an aluminum injection elbow, which is short. The high rise option is stainless allegedly stainless.
Islander 30 MKII "Sojourn"
shogan50 is offline
post #4 of 15 Old 05-06-2011
MARC2012's Avatar
TAD I am pretty sure handels west.Torrenson handels west.Some make them from a 90 with a T,different opinions on this.When mine goes plan on useing a street L & having a machine shop add the water pipe.If you do find a cast one suggest you sit down with stiff drink & prep h.marc
MARC2012 is offline
post #5 of 15 Old 05-06-2011 Thread Starter
Thanks for the replies.
svHyLyte: I requested material info on the Perkins model....looks to fit the spec. thanks.
Shogun: I've never owned a Beta but I have heard good things about them...if it comes with an aluminum elbow maybe I should do some more research.....I don't have experience with this...maybe melting points of aluminum vs mild or galvanized steel? Opinions on this?
Marc: The Westerbeke part I took off was iron, definitely heavier. The replacement is a MMD part....aluminum....which made me look for the spec....which made me wonder. I prefer the pre-made solution because of the length of my "to do" list, but having worked by specs in my job I balk at placing this piece. I appreciate your response.
post #6 of 15 Old 05-06-2011
Break, curse, fix, repeat
bwindrope's Avatar
Hmmm, I replaced the exhaust elbow on my Universal 5432, which is family to the Westerbeke I believe, and the old one had been iron and the new one from Universal was aluminum I believe. I'm not sure, but I seem to remember it being lighter.
In any case, it was the factory replacement for the elbow I had and so I assumed it was compatible for the purpose. What did you hear about aluminum not being a good choice?
Is it a heat issue in the absence of cooling water? Or is it a corrosion issue, in which case iron is definitely afflicted too. What else?
Aeolus
Gulf 32
Bainbridge Island, WA
bwindrope is offline
post #7 of 15 Old 05-07-2011
peikenberry's Avatar
That version of P-1 is really old. So I looked up the current version.
http://newboatbuilders.com/docs/P-1_TABLE-1.doc
It is just the Table of materials. It should open in MS Word
Ike
My Boat building Web Site
My Boating Safety Blog
Dont Tell Me that I can't. Tell me how I can!
peikenberry is offline
post #8 of 15 Old 05-07-2011
Nanni have done the same thing. The new ones are now aluminium (with a zinc).
noelex77 is offline
post #9 of 15 Old 05-07-2011 Thread Starter
Nice!.
Peikenberry: I appreciate that catch, and will check dates in the future. I took the liberty of saving those sites for future caffeinated search missions.
noelex77: Had to google nanni.....interesting site. thanks.
This will make this job much easier. Searching for custom 316 SS work affordably.....I am not going to miss that adventure. Thanks guys!.
post #10 of 15 Old 05-07-2011
There is really no ideal metal for an exhaust elbow. SS does not have a very long life in this application.
I think we could debate which of SS, aluminium, or iron will have the longest life, but they will all need replacing.
When they block with carbon they are very difficult to clean out so maybe a finite life is a good thing, you donít feel so bad replacing it.
Keep an eye on them failure is common and in some cases this allows water into the cylinders.
Inspect every couple of years and consider it a disposable item.
noelex77 is offline
Where do I find an exhaust elbow leeisagenius General Discussion (sailing related) 2 07-24-2010 03:41 PM
2GM20F Exhaust Elbow thisisus Diesel 8 07-19-2009 06:34 PM
Atomic 4 Exhaust Elbow steich Gear & Maintenance 13 12-26-2008 06:57 PM
Universal 5411 exhaust elbow cooltec Gear & Maintenance 2 06-25-2007 06:20 PM
Exhaust mixing elbow I-33 Gear & Maintenance 2 12-02-2006 03:24 PM
