Temp gauge - SailNet Community
post #1 of 5 Old 05-10-2011 Thread Starter
Temp gauge
I have a Univeral 25 on my Catalina 36 and the water temp gauge is not operating. Should I test the gauge or the sender or both. In fact I have no idea where the sender is.
Viking88 is offline
post #2 of 5 Old 05-10-2011
BarryL's Avatar
info
Hello,
The sender should be very near the thermostat. The thermostat is on the front of the engine. just above and to the right of the fresh water pump, ie the engine water pump.
you can see a diagram here
Torresen Marine
Once you find the sensor I would make sure the wire is connected and that the connection is clean.
I *think* that if you remove the wire from sensor and ground it (hold it against a shiny bolt on the engine) the gauge should read full hot.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #3 of 5 Old 05-10-2011
JimsCAL's Avatar
Pretty sure that's correct. Puts 12 volts to the gauge.
JimsCAL is offline
post #4 of 5 Old 05-10-2011 Thread Starter
Thanks guys, I will look into it Wed. I love this boat. Moved it from Chicago and doing a month+ live aboard at Apollo Beach Florida and going to New Port Richie to park it behind the house. She will get plenty of use.
Viking88 is offline
post #5 of 5 Old 05-12-2011
Stu Jackson's Avatar
Get to know these guys: c36.org - c36 Resources and Information. This website is for sale!, and their very good forum. We also have a lot of M25 engine information in our C34 Tech wiki: Catalina 34 - C34
Stu Jackson, C34, 1986, M25 engine, Rocna 10 (22#)
Stu Jackson is offline
Moyer Temp & Oil kit - toruble getting Temp. unit out nigglesworth Atomic 4 3 04-19-2011 04:48 PM
Temp. GPS Disruption aa3jy Electronics 3 01-20-2011 12:49 PM
How to trouble shoot yacht problems with a laser temp gauge DIY yachtwork General Discussion (sailing related) 0 01-01-2010 12:07 AM
At what temp is it necessary to winterize plumbing? davester Gear & Maintenance 21 12-12-2008 03:06 AM
Adding temp. gauge to Yanmar 2GMF dmcgraw Gear & Maintenance 2 06-30-2007 11:14 PM
