Loss of power on a Yanmar 1GM10? - SailNet Community
 1Likes
  • 1 Post By TropicCat
post #1 of 8 Old 05-18-2011 Thread Starter
Would a clogged up mixing elbow cause loss of power on a Yanmar 1GM10? This loss has been extremely gradual.
L.
lawsonmitchell is offline
post #2 of 8 Old 05-18-2011
casey1999's Avatar
L.
From what I understand yes. Take the hoses off and inspected for a carbon blockage. I understand you can clean it out, but will not last long as it will probably be rusted out. If it is clogged get a replacement. Yanmar says these are wear items.
casey1999 is offline
post #3 of 8 Old 05-18-2011
Yes... sounds typical.....
Faster is offline
post #4 of 8 Old 05-18-2011
Senior in age only!!!
centaursailor's Avatar
It,s so common I,m gona check out my exhaust next time I,m servicing the engine.
Safe saiing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
post #5 of 8 Old 05-18-2011
casey1999's Avatar
Safe saiing
I bought a spare mixing elbow for my Yanmar 3gmd just in case. That way if I need it, which someday I will. I have it and do not need to wait if it is back ordered. They are kinda expensive- about $150 as I remember.
post #6 of 8 Old 06-14-2011
Senior Pirate
TropicCat's Avatar
L.
Yes it will, but what makes you think that's the issue? Loss of power is characterized by lower revs at full throttle and is most commonly caused by:
1.) a dirty bottom
2.) barnacles on propeller and shaft
3.) air in the fuel system
4.) clogged fuel filters
5.) old diesel fuel (new low sulfur fuel needs a stabilizer additive)
6.) lastly, dirty injector
I have two of these little gems in my boat and they're good little engines. You'd be wise to check these items first before you reach for your checkbook.
RichH likes this.
Tropic Cat
TropicCat is offline
post #7 of 8 Old 07-31-2014
Send a message via Skype™ to billymc38
Re: Loss of power on a Yanmar 1GM10?
same thing happened to my ysm8 rebuilt it same thing turned out head was bad had rusted through just an idea
good luck
billymc38 is offline
post #8 of 8 Old 07-31-2014
asdf38's Avatar
Are you sure it's the engine?
Note that for it to be an engine problem you'd have to be seeing lower RPM's, not just slower boat speed.
If it's slower boat speed but normal RPM's then it's not the engine - it's bottom growth or weight increases.
If you're seeing lower RPM's at least make sure to check the prop for excessive growth before digging deep into the engine.
asdf38 is offline
Yanmar 1GM10 won't start Sometimesbrilliant Gear & Maintenance 16 08-01-2014 07:00 PM
Yanmar 1GM10 and racor fuel filter. SVDistantStar Diesel 7 01-25-2014 04:46 AM
OMC Saildrive engine loss of power muckitymuc Gear & Maintenance 7 09-29-2009 10:43 AM
Strange Power Loss - Weterbeke 27 craigtoo Gear & Maintenance 17 03-24-2008 08:24 PM
Yanmar 1GM10 cooling system, needs a good cleaning. SVDistantStar Gear & Maintenance 4 01-13-2008 04:14 PM
