Volvo D2-40 fuel filter - SailNet Community
post #1 of 3 Old 06-08-2011 Thread Starter
SoC
I don't know if this has been addressed previously but I have a 2007 Volvo D2-40 diesel and cannot replace the fuel filter. It seems that Volvo discontinued the filter for the engine and gave to same part number to a larger filter that doesn't fit in the space between the mounting bracket and the sensor mounted in the bell housing below it. Authorized repair tells me I need to mount a new bracket. Volvo says it is not covered under my extended warrenty because part hasn't failed. A service guy I spoke with said you might be able to get clearence by loosening mounting bolts and moving bracket and if that doesn't work you "may" be able to add a couple washers underneath to raise the thing. Has anyone had any experience with this, any help would be appreciated. After over a 1/2 hour on hold and talking with Volvo consumer relations the only thing they could offer was an address to send a complaint to.
Does anyone know of a service bulletin on it?
Thanks,
SoC
SoC is offline
post #2 of 3 Old 03-28-2012
Re: Volvo D2-40 fuel filter
Hi there.. I have just bought a boat with the same engine and have the exact same issue and cannot find a solution!
Very keen on how u got on with the issue! Did you manage to find a replacement?
Very annoying problem!!
Many thank
JT
Jamestim is offline
post #3 of 3 Old 03-30-2012
Ah yes, that truly marvellous Volvo service quality again.
Man, doesn't it just bring tears to your eyes?
Rockter is offline
Manta Volvo md2030 fuel filter change? Superick Diesel 1 10-05-2010 05:06 PM
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel 4 06-07-2010 09:01 AM
Fuel Filter ID? sailak Gear & Maintenance 3 09-30-2009 04:22 PM
Racor fuel filter filter guage Grumpymx Gear & Maintenance 5 08-26-2008 08:10 PM
fuel filter changes stm Gear & Maintenance 3 01-27-2003 12:41 PM
