recommendations for a fuel/water separator - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Old 06-14-2011
aspiring sailor
fiestaMojo is on a distinguished road
I'm replacing my fuel tank and lines; I thought I would install a new fuel/water separator. What do folks out there recommend? I was looking at a Racor 120 Series, but the only hard & fast number I can find for application is that it's rate @ 15 gph - I've heard that a small diesel auxiliary uses about 1/2 gph, is this correct? (I'm feeding a Yanmar 2GM20F on a 33' boat). . . thanks for any guidance, Pat
Pat
Boston Harbor, MA
1981 Hunter 33
Reply With Quote Quick reply to this message Share with Facebook
You may post attachments
You may edit your posts
fuel/water separator? jimmy Diesel 6 05-30-2011 07:16 AM
Parker R12P Fuel/Water Separator bobmorning Gear & Maintenance 1 08-25-2010 08:46 PM
Fuel filter/water separator Waltthesalt Diesel 8 01-08-2010 09:00 PM
Fuel/Water Separator Maintenance? SEMIJim Gear & Maintenance 27 09-22-2007 10:46 PM
Attwood fuel/water separator sailhog Gear & Maintenance 13 07-31-2007 06:16 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
