Yanmar 4JH-2E using coolant - SailNet Community
post #1 of 8 Old 07-12-2011 Thread Starter
Tim R.'s Avatar
Here is what I know:
- Engine runs very well with ample power at all rpms
- I have to top off the overflow tank after every 4 hours of motoring
- No overheating(yet)
- No coolant in oil(crack in block)
- No pressure in heat exchanger when running the engine with the cap removed(bad head gasket)
- No apparent leaks under the engine
What is left are the following:
- Hot water heater leak
- Heat Exchanger leak
- Exhaust riser leak
- hidden leak into bilge
- Something I am missing?
Any of these should have coolant in the bilge, hot water system or the exhaust. Does anyone know of a way to test for coolant(trace amounts) in water?
Tim R.
Our Carina is for sale
1997 Caliber 40LRC
Tim R. is offline
post #2 of 8 Old 07-12-2011
Assuming there is water in the bilge, I have read that dogs will drink it because it is sweet? If you don't want to taste bilge water there may be some sort of dye that will show up under an ultra violet light?
Dabnis
dabnis is offline
post #3 of 8 Old 07-12-2011
Dabnis
Ultra violet leak detector: Black Light World - Fluorescent Tracer Dyes
Dabnis
dabnis is offline
post #4 of 8 Old 07-12-2011
Courtney the Dancer
jrd22's Avatar
I think I would try to isolate where the leak is by disconnecting the lines to the hot water heater. If you are still using coolant then it's got to be engine. You said that there was no pressure in the overflow with the cap off while running but wouldn't it be more apparent if you left the cap on so the pressure built up? There is a way to check if exhaust gases are present in the coolant, an automotive parts store should have it.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #5 of 8 Old 07-14-2011
Sailing to surf
Beersmith's Avatar
I have the same engine and had the same problem. Turned out to be the hot water heater.
My boat rebuild/sailing blog:
Beersmith is offline
post #6 of 8 Old 12-06-2013
Re: Yanmar 4JH-2E using coolant
This post is old, but relevant to me maybe. Could you elaborate? How can the hot water heater be related to the fast use of coolant by the yanmar engine? Thanks in advance,
Alexandra.
agoffin is offline
post #7 of 8 Old 12-06-2013
Possibly a small leak from the coolant piping inside the heater into the fresh water supply? Generally, after the engine warms up there is pressure in the coolant system, assuming you have the filler cap secured. If you taste the hot water and is sweet, it has coolant in it. As the anti freeze is toxic, don't taste too much of it, maybe a drop on the end of your finger? or, as mentioned earlier, use a fluorescent dye in the coolant, safer that way.
Paul T
dabnis is offline
post #8 of 8 Old 12-06-2013
chucklesR's Avatar
Simple, cheap and effective way to check - put dishwashing soap in the coolant tank.
If you blow bubbles you have a leak in the exhanger.
Same thing works to make sure your impeller is working (if you have an under water exhaust) - soap the impeller - crank the engine and look for bubbles.
chucklesR is offline
Yanmar YM coolant leak ctlow Diesel 3 06-11-2011 06:30 AM
2003 Yanmar, 765 hours - milky oil, overheating, evacuating coolant vpo3 Diesel 2 05-10-2010 11:33 AM
Yanmar coolant replacement Norstar Pacific Seacraft 8 11-11-2009 09:47 AM
Coolant Change ahalfon Gear & Maintenance 6 10-28-2008 07:43 AM
Coolant valdon34 Pacific Seacraft 0 07-18-2008 01:45 PM
