fuel filter leaks (or better sweats) - SailNet Community
post #1 of 5 Old 07-18-2011 Thread Starter
I have got a Delphi 296 fuel filter with metal bottom separator. It is installed downstream of the fuel pump so the fuel pump is actually pumping diesel into it and no matter what the little nag 'sweats' diesel through the bottom seal ring and since the engine is next to my bunk I can smell it and I don't like that.
I evenreplaced the filter cartridge and seals with new one but that hasn't changed anything of the situation.
I tried to tighten more and more but with no avail.
Any suggeston or shoul I move to a RACOR filter directly?
KindRegards
scud is offline
post #2 of 5 Old 07-18-2011
Once known as Hartley18
Classic30's Avatar
Dock
Perhaps the unit you have isn't designed to be pressurised.. Racor filters aren't expensive and I don't see any particular reason why the filter filter needs to be downstream of the pump.
I'd suggest you buy a new Racor filter setup with the clear bowl, install it upstream of the pump and replace the existing with a length of flexible fuel hose.
Classic30 is offline
post #3 of 5 Old 08-05-2011
In my experience filters work better when upstream of the a pump, so they're under vacuum rather than pressure. Under vacuum they shouldn't leak either! Of the boats we look at with fuel issues, I'd say 95% of filters are upstream... I'd move the filter upstream if it were me.
charisma94 is offline
post #4 of 5 Old 08-05-2011
Up stream of the pump any leak is an air leak and your engine won't run right, that said you will find a leak up stream much sooner than one downstream.
wescarroll is offline
post #5 of 5 Old 08-10-2011
i would guess your plate where the seal rides is warped or pitted so a replacement is needed.
bandaidmd is offline
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel 4 06-07-2010 09:01 AM
Fuel Filter ID? sailak Gear & Maintenance 3 09-30-2009 04:22 PM
Racor fuel filter filter guage Grumpymx Gear & Maintenance 5 08-26-2008 08:10 PM
fuel filter changes stm Gear & Maintenance 3 01-27-2003 12:41 PM
diesel fuel filter tho52mas Gear & Maintenance 2 05-16-2002 10:26 PM
