Yanmar transmission oil - SailNet Community
post #1 of 8 Old 08-02-2011 Thread Starter
Crealock 37
sailak's Avatar
Dock
I'm wanting to change the tranny oil in my 3GM30F with a Kanzaki KM3P transmission. My service book say to use what's on the data plate on the tranny -- that has oil type as "SAE 20/30 HD". What is that?
An online source says to use "same as engine oil" -- I use Delo 400 10W30.
I'm thinking a straight 30 weight engine oil is okay.
Thanks in advance.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
sailak is offline
post #2 of 8 Old 08-02-2011
One of None
deniseO30's Avatar
I found this.. Looks like yours is listed and yes on engine oil too.
TRANSMISSION TYPES
My Hurth uses ATF
My last project!
deniseO30 is offline
post #3 of 8 Old 08-03-2011 Thread Starter
Crealock 37
sailak's Avatar
Dock
Thanks Denise.
I had also found that sight. Sucked a sample out, it was NOT ATF so put 30W oil in on the refill.
Dale
S/V Elnora
sailak is offline
post #4 of 8 Old 08-03-2011
RichH's Avatar
Thanks in advance.
SAE 20/30 HD is 'straight weight' SAE 20 or 30 .... not a multi-viscosity grade such as 10W30 etc.
... and YES (For essentially ALL Yanmars) the ID of the transmission lubricant is stamped/engraved ON the transmission plate and NOT what is listed in the 'service manual'.
RichH is offline
post #5 of 8 Old 08-03-2011 Thread Starter
Crealock 37
sailak's Avatar
Dock
Thanks Rich,
I'd assumed that it was a choice of 20 or 30 weight oil.
Dale
S/V Elnora
sailak is offline
post #6 of 8 Old 08-04-2011
"HD" oils are "detergent" oils, not the same as plain SAE-rated oils.
Most of the oil you'll find in the stores is HD-rated.
hellosailor is offline
post #7 of 8 Old 08-15-2011
yanmar recommends that you not use either the hd or the mixed weight oils in its engines. here in the great alkes, straight 30 weight goes into both the engine and the gearbox (transmission.)
MitchM is offline
post #8 of 8 Old 08-17-2011
casey1999's Avatar
Would straight 40 weight be ok?
casey1999 is offline
Yanmar 2GMF Transmission Oil? dacap06 Gear & Maintenance 4 04-19-2010 11:03 PM
yanmar transmission dissasembly hertfordnc Gear & Maintenance 2 02-11-2009 11:58 AM
yanmar transmission compatibility hertfordnc Gear & Maintenance 0 01-16-2009 01:24 PM
Yanmar 3gm30 transmission olepedersen@yahoo.com Gear & Maintenance 7 10-06-2008 11:10 AM
yanmar transmission rbtpfe9 Gear & Maintenance 0 09-06-2005 10:46 AM
