Volvo Penta 2002 18 hp. after 5 to 30 minutes - SailNet Community
post #1 of 6 Old 08-03-2011 Thread Starter
My Volvo Penta 2002 18 hp 2 cylinder diesel engine start easy, sounds and runs good from 5 to 30 minutes. It then stops like it is not getting fuel. It has new fuel,new filters and seperators that were topped off with fuel when they were installed. Any suggestions?
jtsail
jtownsail is offline
post #2 of 6 Old 08-03-2011
Once known as Hartley18
Classic30's Avatar
Dock
jtsail, welcome to Sailnet. When you get a chance an introduction post in the Introductions section might be nice.
You've probably got air getting in somewhere. Bleed the fuel system right through to the injectors and see if that makes a difference.
Classic30 is offline
post #3 of 6 Old 08-03-2011
the pointy end is the bow
erps's Avatar
Some boats have a screen in the fuel tank pickup tube. Run the motor, the screen plugs up. Stop the motor, the fuel sloshing around in the tank partially washes off the screen, just enough so it will run for a bit until it plugs up again.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #4 of 6 Old 08-03-2011
Perhaps the tank is not venting properly or a partially plugged pickup tube if it has a screen on it. All connections on the vacuum side of the pump should be checked, or perhaps the filter itself is sucking air somewhere?
dabnis
dabnis is offline
post #5 of 6 Old 08-03-2011
erps's Avatar
if you get a jerrycan of diesel and stick a hose in it and plumb it to the fuel system to bypass your tank, and it runs, it would point to the tank or the fittings to the tank or the plugged vent line as dabnis mentioned (good call btw)
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #6 of 6 Old 02-09-2015
al brazzi
Re: Volvo Penta 2002 18 hp. after 5 to 30 minutes
Do you have the engine manual there is a screen that needs to be checked and cleaned every so often up high on the front of the motor (I'm not looking at it right now so I cant tell you exactly where) Top of the fuel pump maybe. I can look at my manual if you need and there is an online source for the manual I will see about a link.
albrazzi is offline
Volvo 2002 injector GerryC Diesel 3 12-20-2010 05:26 PM
Help! Volvo Penta Md5b?!?!?!?! anotherfng Diesel 3 08-08-2010 07:27 AM
Volvo Penta 39 jernhenrik Gear & Maintenance 0 10-18-2009 12:00 PM
Volvo Penta 2002 18 hp - turn key, Nothing! dwayne908 Diesel 17 08-30-2009 02:14 AM
Volvo 2002 Crankcase high pressure Esio Diesel 3 07-30-2009 08:56 AM
