Aluminum Diesel Tank Fabricators? - SailNet Community
post #1 of 4 Old 08-03-2011 Thread Starter
Señor Member
PorFin's Avatar
Hi all,
I'm looking for recommendations on reputable & reliable fabricators for aluminum diesel tanks.
I need to have twin saddle tanks made, with a bit of tricky geometry involved. I'm looking for a fabricator that does quality work.
Any suggestions?
Thanks in advance,
PF
PorFin is offline
post #2 of 4 Old 08-03-2011
I'm not sure where you're located but most good diesel repair shops and yards can fabricate a tank. I had a new tank made by List Marine in Sausalitio—they did a great job. Good luck.
olgriz is offline
post #3 of 4 Old 08-04-2011
Thumbs up Here's just one...
PorFin,
First: How about filling some basic boat and location info? This helps other sailors help you.
I had these guys build my new custom-design diesel tank. Excellent workmanship and on-time.
Coastline Equipment, custom marine tanks.
If you need a link to my custom tank project, email me back channel.
LB
olson34 is offline
post #4 of 4 Old 08-04-2011 Thread Starter
Señor Member
PorFin's Avatar
OK, fair enough.
The boat's a 1985 Vagabond 39.
The original tanks were/are steel encapsulated in a layer of glass -- long sad story, but the port side tank finally succumbed to water trapped between the glass and the steel. If you want gory details, there's a long post over on AS including pictures.
The boat's a little south of Annapolis, so east coast fabricators are preferred.
These are twin tanks (port and starboard), each nominally about 55 gal. They're not square or rectangular, but a modified wedge.
I guess what I'm asking for is some help in identifying a shop that has a proven track record in making good tanks. Any monkey with a MIG or TIG set can weld aluminum, but I'm looking for quality results with an assurance that proper materials are used and designs followed. I'm a little leery of taking company internet home page info at face value, so feedback from those with experience will be invaluable.
PorFin is offline
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 05:38 AM
Life expectancy of aluminum diesel fuel tank jbrockpiano Gear & Maintenance 7 10-27-2008 03:26 PM
Aluminum diesel tank ekotopia Gear & Maintenance 11 01-19-2008 08:19 PM
aluminum diesel tank mary jewell Gear & Maintenance 2 10-05-2004 06:38 AM
aluminum water tank CISCOJOE Gear & Maintenance 4 07-15-2002 06:56 AM
