shifting issue transmission of 2QM15 Yanmar - SailNet Community
post #1 of 3 Old 08-05-2011 Thread Starter
Cool shifting issue transmission of 2QM15 Yanmar
I recently purchase a 31' Bombay Sloop - it has a 2QM15 Yanmar. I had a bottom job and shaft aligned. Now I am experiencing an issue with shifting forward and reverse. I am guessing it is in the shifting lever, but I would love some advise before I just start ripping into it...
LiaSophia is offline
post #2 of 3 Old 08-05-2011
Shift lever and linkage is the first place(least expensive) place to start when you have a shifting problem. Go there first, make sure it runs smooth and with no catches.
wescarroll is offline
post #3 of 3 Old 08-05-2011
fryewe's Avatar
If you have the Morse dual levers for fuel control and transmission, and they haven't been serviced (disassembled and lubed) since the boat was built like most, it is likely that dirt and corrosion have built up around the shaft of the controls. I had difficulty shifting between forward and reverse, and also, while shifting directions, the friction would pull the fuel control lever out of its set position. It was a PITA, making engine control a two handed operation. The only solution was to disassemble and lube (I cleaned with WD40 and lubed with white grease). Solved the problem and made life a lot simpler and safer.
If you have the dual lever Morse control and don't have the drawings, I have digital copies and could send them to you. PM me if you need and want them.
fryewe is offline
Yanmar 2QM15 sundownersc Diesel 11 02-09-2012 09:21 AM
Yanmar 2QM15 repairtime Gear & Maintenance 7 12-09-2011 04:40 AM
Help with yanmar 2qm15 stuck transmission Waterman28 Diesel 2 05-05-2011 02:44 AM
2qm15 motor mounts and transmission alignment kegendron S2 2 03-08-2011 07:24 PM
Yanmar 2QM15 rpowell Gear & Maintenance 3 01-10-2002 08:26 PM
