yanmar cockpit panel. - SailNet Community
post #1 of 10 Old 08-24-2011 Thread Starter
NewportNewbie's Avatar
My new to me Santana 30 has a yanmar diesel in it. The panel with the tach and key has the film with the writing on it peeling off. Where can I replace that?
S/V Cuajota - 1975 WD Schock Santana 30
NewportNewbie is offline
post #2 of 10 Old 08-24-2011
Undadar's Avatar
I see Panel Visor advertised in Good Old Boat magazine. Might give them a try. PortVisor rain shields for opening portholes ~ from Seaworthy Goods
http://jdfinley.com
You can observe a lot just by watching.
Undadar is offline
post #3 of 10 Old 08-24-2011
check out Mack Boring & Parts Company - The Power Behind The Power or Sailboat Hardware, Sailboat Engine Parts and Boating Supplies - Torresen Marine - The Sailboat Specialist for new or other info. I Have always found both very helpful. For used try EBay. There are several different sizes available that would work.
That derelict boat was another dream for somebody else, don't let it be your nightmare and a waste of your life.
badsanta is offline
post #4 of 10 Old 08-26-2011
Senior in age only!!!
centaursailor's Avatar
My panel is recessed and is partially shielded by clear plastic.
Looks like the port visor would have the same effect if retro fitted.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
post #5 of 10 Old 08-29-2011
Crotchety Old Member
tomperanteau's Avatar
I researched a bit and emailed someone that deals in Yanmar parts (I have the same model). I was told that you have to buy the complete panel, including the circuit board, and the cost is around $108. A shame that you cannot buy just the template. Mine has peeled off and that is all I needed.
Capt'n Tom Living Aboard 50/50
S/V Footprints
Youtube
1976 41' Morgan Out Island Sloop. Refitting and redoing her interior for an extended voyage.
tomperanteau is offline
post #6 of 10 Old 08-29-2011 Thread Starter
I found a local place that has it for $105. He told me it was merely the entire plastic front, not the electronics. He could be wrong. I'll probably get it and the plastic protection cover also listed above.
post #7 of 10 Old 08-31-2011 Thread Starter
Just replaced my panel. It was 105 for the panel. It's only the panel. No electronics. I had to swap all my old stuff.
post #8 of 10 Old 08-31-2011
Irrationally Exuberant
I think I've crossed some threshold of boat ownership regarding costs. I saw the picture of the new plastic panel and the price and thought "A hundred bucks? Not bad". Looks nice though.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #9 of 10 Old 09-04-2011
When I installed my Yanmar 2GM, I recessed my control panel and put a clear plastic door over the recessed panel. The control panel looks new (it is 19 years old now), I've changed the clear plastic door twice, for cheap.
luck66 is offline
post #10 of 10 Old 09-05-2011
Gary M's Avatar
My panel was cracked when I bought the boat so I cut a piece of 3/16" aluminum to fit including the holes for gauges etc. and just placed it over top.
Looks OK and is very strong and cost just my time.
Gary M is offline
Yanmar 3YM20 Oil Pressure Alarm with B Engine Panel CapitainMike Electrical Systems 0 07-22-2011 01:26 PM
Yanmar instrument panel source -used? mbsl98 Diesel 3 05-10-2011 12:30 PM
Yanmar control Panel PeteSS Diesel 4 08-29-2009 01:33 AM
Cockpit switch panel...relays? LifeWorthLivin Gear & Maintenance 17 05-22-2008 08:52 PM
Aft Cockpit vs Center Cockpit AjariBonten Boat Review and Purchase Forum 26 11-05-2007 01:53 PM
