Engine compartment forced ventilation? - SailNet Community
post #1 of 4 Old 09-06-2011 Thread Starter
I own an 1986 Freedom 36 which has originally fitted Yanmar 3GM30F in what appears very confined and closed compartment which I find well insulated (heat and noise). Front engine access is through rather large cover under the companionway stairs which provides reasonable access for maintenance and inspection. Through the Port aft locker space there is back access to that space for cooling water intake valve and gearbox oil change as well as drive shaft dripless seal, exhaust etc. On the back of that there is a round hole with a fan and ducting which wasn't in use when I purchased the boat. My question is whether that fan is to supply the fresh air to the engine compartment or to extract the heat from the engine compartment? Apart from that opening (for the fan) and several holes for passing the battery cables there is no direct supply of air to the engine but i have not observed any problems with the engine running. Any thoughts?
Petar is offline
post #2 of 4 Old 09-06-2011
JimsCAL's Avatar
The enigne box for the 3GM30F in my Cal 33-2 is fed with two large (5-6 inch) ventilation hoses that terminate in cowls on the transom. Always thought this was a great arrangement.
JimsCAL is offline
post #3 of 4 Old 09-06-2011
Beneteau provides a ventilation fan that runs when the engine is running.. I think it's a great idea that will reduce heat buildup and odours. You might want to put that back in service.
Faster is offline
post #4 of 4 Old 10-27-2011
Diesel require a lot air just to breath let alone cool the engine compartment.Deal with it.
Capt Len is offline
Soundproofing PS Engine Compartment RainDog Pacific Seacraft 4 03-28-2011 05:44 AM
Soundproofing Engine Compartment Allanbc Gear & Maintenance 17 12-01-2010 03:06 PM
Water in engine compartment nightsky Gear & Maintenance 17 09-25-2010 06:40 AM
Engine compartment ventilation? Petar Gear & Maintenance 6 03-29-2010 12:51 PM
Engine ventilation PBzeer Gear & Maintenance 7 03-04-2007 11:52 PM
