Yanmar 2GM Knocking - SailNet Community
 1Likes
post #1 of 12 Old 09-24-2011 Thread Starter
Yanmar 2GM Knocking
My 1984 Yanmar 2GM has started knocking when it's in forward above 3000 RPM. It doesn't happen in neutral, so I wonder if it's a transmission problem. Any suggestions would be appreciated. It sounds like metal to metal. I hauled it this week. and the prop seems to be o.k.
WilliamDMoore is offline
post #2 of 12 Old 09-24-2011
JimsCAL's Avatar
Sounds like unbalance to me. Were there barnacles or other fouling on the prop when you hauled?
JimsCAL is offline
post #3 of 12 Old 09-24-2011
jimrafford's Avatar
Could be the shaft in the stern tube. Check your engine alignment.
JIm
S/V Deja Vu
CS 40
jimrafford is offline
post #4 of 12 Old 09-24-2011
MarioG's Avatar
Dont rule out dirty injectors. Under load it requires more fuel, You get whats called an octain knock if the injectors are dirty and not able to feed the correct amount of fuel.
MarioG is offline
post #5 of 12 Old 09-24-2011 Thread Starter
Jimscal - I'm sailing fresh water, and when I hauled, the prop was clean.
Jim Rafford - I checked the engine mounts, and it seems solid. How else would it get out of alignment?
Mario G - I have since looked at other posts, and can't rule out a fuel problem. I did some aggressive sailing this season, and suspect that I churned something up from the fuel tank. I need to find instructions on cleaning/changing injectors etc.
Thanks to all.
post #6 of 12 Old 09-24-2011 Thread Starter
Oh yes - there was some dark smoke when it was knocking which might also indicate a fuel mixture problem.
post #7 of 12 Old 09-24-2011
JimsCAL's Avatar
The black smoke could indicate overloading. Was the bottom fouled?
What about play in the strut bearing? If worn that could result in knocking.
JimsCAL is offline
post #8 of 12 Old 09-24-2011
This sounds a lot like a 'bad' injector... try bleeding each injector momentarily when it's knocking... the knock will disappear when you disable the offending one.
What usually happens is the injector fails to atomize the fuel properly and the 'knock' (which sounds alarmingly like metal-on-metal) is caused by trying to compress liquid fuel. If the smoke is more 'brown' than black that's another indicator of this issue.
Faster is offline
post #9 of 12 Old 09-25-2011 Thread Starter
Thanks all
I was talking to another owner with the same engine yesterday, and he suggested an oil additive that has an injector cleaner in it. Does anyone know of one? The boat is hauled, so I won't do anything until next spring. Our season is very short in Canada.
post #10 of 12 Old 09-25-2011
There are various fuel additives that claim injector cleaning properties..
twisted23 likes this.
Faster is offline
Loud knocking with black smoke - Yanmar 70 dillybar General Discussion (sailing related) 6 06-13-2011 09:27 PM
Yanmar 4jh 8te jbondy Diesel 3 10-30-2010 07:30 PM
yanmar ysb 8 ecarson General Discussion (sailing related) 0 08-25-2010 02:08 PM
Yanmar value 71Irwin32 General Discussion (sailing related) 4 01-01-2010 09:43 PM
Yanmar 1 GM Knocking MikeM Diesel 9 10-09-2009 09:08 PM
