Now that I killed the 3gm30 - Page 3 - SailNet Community
 1Likes
post #21 of 24 Old 10-26-2011
If it's determined to be an accident then it should be covered
aa3jy is offline
post #22 of 24 Old 10-26-2011
Originally Posted by ereiss View Post
What am I missing (other than piece of mind)?
Well for starters you can put a proper engine for the size boat that you have. About a 35 hp engine min. would be needed for your 38 Freedom..however..what I found interesting ..when I looked at the Freedom 38's on Yacht World that where for sale..they all had 3GM30's with one exception and that one had a 3YM30.
aa3jy is offline
post #23 of 24 Old 10-26-2011
Over Hill Sailing Club
smurphny's Avatar
Did you need a new block? 8K sounds like a lot if all they need to do is replace a piston and rod.
smurphny is offline
post #24 of 24 Old 10-27-2011
casey1999's Avatar
1. I don't know if insurance will cover it but I put it in the category of "it's worth a try". They had the survey come out this week to look at it. We'll see what happens.
Now have pricing and choices;
1. Rebuild by Mack Boring, 6 month warranty (from when it splashes in the spring) cost, about $8,200 all in (remove, rebuild, reinstall).
2. Can purchase a new Beta30 for about the same amount but install will be somewhere between 50 and 100 hours.
So option 2 costs twice as much as option 1 (no, not planning on doing a self install even though Beta says 50% of buyers do it themselves). I have a hard time thinking that new is twice as good or will add that much "value" to the boat if/when it needs to be sold.
I would go with the rebuild. That rebuild engine might be better than a new one, or at least last as long. When you splash her, run the engine a lot in first 6 months, if it is good for 6 months I would think it will be good for a long time.
If you do decide to go with the Beta, would be nice to get a fixed install price in the low end of the range.
Good luck
casey1999 is offline
Yanmar 3gm30 F....removing Drive disc S34 Diesel 17 10-10-2016 06:41 PM
Yanmar sticky throttle (3GM30) ddaggett Gear & Maintenance 0 02-01-2011 01:25 AM
Yanmar 3gm30 transmission olepedersen@yahoo.com Gear & Maintenance 7 10-06-2008 12:10 PM
IP31 yanmar 3gm30 badsanta Island Packet 10 06-07-2008 01:34 AM
Replacement prop on a Yanmar 3GM30 dave6330 Gear & Maintenance 0 10-22-2007 04:10 PM
