no start Yanmar - Page 6 - SailNet Community
 3Likes
post #51 of 54 Old 10-21-2012
Omatako's Avatar
Re: no start Yanmar
I don't know whether you have solved your problem or not because I never read all the posts but I'll offer this in case the problem persists.
I have a two cylinder Kubota in my genset and I left it unstarted for about a year. when I came to start it it coughed once or twice then each time I tried starting it, it started running for a few seconds before dying.
After a long search of the fuel system, I randomly pulled the rocker cover off and discovered that one of the valves had stuck down and the pushrod had jumped out of the socket in the rocker. So I had just one cylinder with compression and that was enough to fire but not to keep the engine running.
Refitted the pushrod, eased up the valve with WD40, started her up and she runs sweetly again
There were no strange noises or anything to indicate a mechanical issue so the naysayers who are going to say it would make a noise are wrong. Once the push rod jumps out, the valve simply doesn't work anymore.
I don't know if Yanmar is the same as Kubota, on the Kubota the valve doesn't appear to go deep enough to touch the piston so no long term damage resulted from the valve sticking down
Try it. it only takes a few minutes to lift off the rocker cover.
Arthur C. Clarke
Omatako is offline
post #52 of 54 Old 10-21-2012
Re: no start Yanmar
...after 56 hours of "hell in the engine room".. That is EXACTLY WHAT HAD HAPPENED.!
After 5 years on the hard and only 33 hours on a new Yanmar 3 cylinder....#2 injector plunger was STUCK..! now running like a Swiss watch.! Thanking you "ALL".. on the forum for your support.! Look forward to becoming a helpful contributor.
I remain, sincerely Dick Rawlings Oxford, Maryland.
Anytime anyone is in the neighborhood please give me a call for a get-together.!
Best..! ..and "thanks again ALL"!
Ameridacusa is offline
post #53 of 54 Old 10-22-2012
casey1999's Avatar
Re: no start Yanmar
Good to hear..
casey1999 is offline
post #54 of 54 Old 10-27-2012
Re: no start Yanmar
If I may chime in on this, as a general rule a diesel produces 3 different colored smokes. White smoke usually means starvation of air, blue smoke means presence of oil (bad rings, etc), black smoke means engine under heavy load. You stated prop complained. I would look for a problem in driveline, I.E. bearing box, transmission. It definitely sounds like a loading problem.
Paladin is offline
Yanmar 1GM10 won't start Sometimesbrilliant Gear & Maintenance 16 08-01-2014 06:00 PM
Yanmar 3YM 30 start battery Brahmany C320 3 03-06-2011 06:00 AM
yanmar 2qm 20 will not start lordpoltimore Diesel 13 03-08-2010 01:26 PM
my yanmar 2gm20 will not start henrystanley Gear & Maintenance 6 06-25-2007 01:48 PM
Can't start My Yanmar bun243 Gear & Maintenance 8 06-04-2006 01:22 AM
