Volvo Heat Exchanger 2002BT - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Old 11-07-2011
AlAlexander is on a distinguished road
I had a nightmare this summer when my heat exchanger on a Volvo200BT (in a Beneteau390) gave up the ghost.
the new part from Volvo is listed at $3400 (not a typo). I found it discounted at $2,700. I searched around for a used one, found a couple and figured I wouldn't be moving ahead with a used part. I contacted Sen-Dur, who make heat exchangers, in Ft Lauderdale and they jerked me around for a couple weeks. Then I found Orca Manufacturing (also make heat exchangers) in Washington. Dave there helped me through the design and manufacturing and got it to me for about $1,000. (1 boat unit). My mechanic ate up another boat unit or so plumbing the new one but now I have a new HE that has a zinc (original part does not) and can open at both ends, on the engine for picking out small pieces of rubber after you melt an impeller or stuff gets into it otherwise. With about 40 hours on the new one I am quite happy with the repair and finding Orca. FYI!!
L124C likes this.
Reply With Quote Quick reply to this message Share with Facebook
You may post attachments
You may edit your posts
Oil in Heat Exchanger sailak Gear & Maintenance 38 08-07-2010 09:28 PM
Heat Exchanger help DBboat Gear & Maintenance 14 05-20-2008 05:57 PM
heat exchanger Jovietal Gear & Maintenance 4 04-03-2007 04:59 PM
Transmission Heat Exchanger gconley Gear & Maintenance 7 11-05-2006 10:45 PM
Heat Exchanger (Perkins 4-108 loa36 Gear & Maintenance 1 07-10-2004 11:58 AM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
