Racor Fuel Filter - SailNet Community
post #1 of 3 Old 02-08-2012 Thread Starter
Ticon 30
dbruce85's Avatar
Racor Fuel Filter
As we are getting closer to the sailing season here in Canada, I am starting to think more about the boat.
I have a Racor fuel filter as the primary filter on a Universal 5411. Last season was my 1st. with this boat. After about 10/15 hours of running the fuel was down about an inch or so in the glass bottle. I did change the filter so it was clean. Topped it up and the same thing happened again.
Is this normal or is there a small air leak.
Thanks
David
dbruce85 is offline
post #2 of 3 Old 02-08-2012
pdqaltair's Avatar
Air Leak
That's only normal when there's a leak.
I've run them for many years, both on boilers and in boats.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #3 of 3 Old 02-08-2012
Bruce :
You are drawing air, my friend.
You may think of using a pressurised system.
Any of these pumps will do it....
Electric Fuel Pumps - Stewart Warner
They are not expensive, at about $80 or so.
Using a pressurised system will add to the fire risk, but the starting reliability of the motor is transformed. You can put the fuel pump on an on/off switch. Once fitted, you simply cannot get an air leak downstream of the pump. You can get the occasional fuel leak, but you see where it is leaking out and you can fix it.
Crucially, the motor won't stop in the meantime.
Without the electric pump, I had the motor stop more often that I could tolerate.
Rockter is offline
Yanmar 1GM10 and racor fuel filter. SVDistantStar Diesel 7 01-25-2014 03:46 AM
Racor fuel filter filter guage Grumpymx Gear & Maintenance 5 08-26-2008 08:10 PM
Racor Fuel/water filter wchevron Gear & Maintenance 5 04-22-2008 09:10 PM
Racor Filter NautiG Gear & Maintenance 2 12-24-2007 02:12 PM
Racor Fuel Filter aphil138 Gear & Maintenance 2 03-15-2004 02:20 PM
