filtering very dirty diesel - SailNet Community
post #1 of 12 Old 02-16-2012 Thread Starter
I live in the Solomon Islands and recently bought for a song, a small diesel powered launch.
Rebirth of the M.V Pagu
I live in a remote place so the diesel fuel I'm able to source comes from all sorts of dubious places and guaranteed to contain just about anything from sediment to water.
In the boat, I plan to put in line from tank to engine first a simple bowl water separation filter, then a primary CAV filter, than the secondary on the engine.
When I buy diesel (to purchase I put word out and it arrives to me in a variety of any kind of container that will hold it in various volumes, origin unknown but probably 'highjacked' from the loathed Malaysian logging camps) I let it sit for a while the syphon of the top 90% leaving the last litre or two.
I've been wondering how to do some filtering at the pumping end before I put into the tank?
And wondering if any point in putting more than one primary filter before the engine?
Any advice out there on working with dirty diesel would be very appreciated.
Pagu is offline
post #2 of 12 Old 02-16-2012
CaptainForce's Avatar
You might want to look at the commonly used "Baja" filter,- a stacked set of gradient sized filtering funnels used at filling from a suspicious source. Practical Sailor did a review of these types of filters in some past issue and they rated West Marine's version quit well. I've never used one so I'm only speaking of second hand hearsay. Check them out,- take care and joy, Aythya crew
CaptainForce is offline
post #3 of 12 Old 02-16-2012
Isn't someone going to suggest he bolt on a mast and hoist a sail instead? There are club rules here after all......
I would also recommend that the filtering be done before it goes in your tank. Then your onboard filter should be able to get suspended (emulsified) water out, if it separates further.
Jeanneau 54DS
Minnewaska is offline
post #4 of 12 Old 02-16-2012 Thread Starter
Thanks for much for the tip. I’ll check out the ‘baja’ type filter. I’m using something similar Available in Australia called a ‘Mr Funnel’. Has fine mesh and a little sump to catch water.
As the comment re raise a mast. Yes an obvious idea and I do plan to fashion something for the few months of the year when the SE Trade winds reach my location. If Minniewaska knows their geography they’ll be aware that much of the Solomon Islands lies in the doldrums. More than 9 days out of 10 are glassy calm. Not a breath of wind and that’s no exaggeration! I had a 38’ sail boat there for the last 4 years (I bought her back to Australia in November and just sold her last week). I did thousands of miles with that boat in the Solomons, but sadly only a handful under sail. The majority was pushing a 9 metric tonne performance sailboat on a woefully undersized axillary engine. I now have a similar sized engine in a hull weighing only hundreds of kilos rather than thousands. Less poetic, but infinitely more practical for the location.
Pagu is offline
post #5 of 12 Old 02-16-2012
Bristol 45.5 - AiniA
I have a West Marine filter (a cheaper version of the Baja which is stainless rather than plastic). Don't know if the one you have is the same, but it is very good at flitering out water and larger pieces of crap. Main advantage is that it saves having to replace the Racor elements all the time and can handle large amounts of water. You need to put the fuel through the filter quite slowly if the fuel is really contaminated - which sounds like it for you.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
post #6 of 12 Old 02-16-2012
Have removed the bottom of a 2 litre Pespi bottle and together with
some coffee filters became our fuel filter and tank, got us home just
fine. ...however I think below might be more useful to you!
In addition to good filters referenced in above posts...
Have found this site helpful...talks about water eliminators,
the worth of fuel stabilizer in regard protecting motor, and a little
insight to the degrading of diesel fuel when unused diesel is recycled to tank. www.mydieseldoctor.com/FAQ
HUGOSALT is offline
post #7 of 12 Old 02-16-2012
www.mydieseldoctor.com/faq
Go to technology section then FAQ
HUGOSALT is offline
post #8 of 12 Old 02-16-2012 Thread Starter
Thanks very much HUGOSALT! Some good informative reading there.
Pagu is offline
post #9 of 12 Old 02-16-2012
Let me be the first to give you a proper "welcome" to sailnet.
Good luck with Pagu ... gave your blog a look...great pics
especially like the "down south" overwinter shots in the Antartic favorites being the winter shots of the huddle and the Aurora over the huddle.
HUGOSALT is offline
post #10 of 12 Old 02-16-2012 Thread Starter
Thanks very much for the welcome & point taken from Minnewaska re 'hoisting a sail instead....club rules here after all'. The boats I've owned in the past I've bought barely even considering the engine with all attention on the sails and rig (technology I can work with). Life in the doldrums though is a different matter. The winter in Antarctica blog you made reference to: Very special experience that one. Like being at sea in many ways living out on the sea ice for months. Magic.
Back to things oil & diesel though. This I found a good practical read too.
How to clean diesel fuel tanks in boats
Pagu is offline
Are You Filtering your Fresh Water? stuartsw Provisioning 38 02-05-2010 02:06 PM
Dirty Gas ccriders Gear & Maintenance 11 08-22-2009 01:46 AM
Diesel tank dirty, clogging filters, 3 days to fix ... best options? FishFinder Gear & Maintenance 25 07-05-2009 02:16 PM
diesel fuel tank dirty again.... saltypat Gear & Maintenance 14 11-05-2007 11:25 AM
Filtering diesel fuel? jswwrites Gear & Maintenance 4 09-14-2006 02:11 PM
