160 degree Tstat for my Univ 5416? - SailNet Community
post #1 of 11 Old 02-21-2012 Thread Starter
One of None
deniseO30's Avatar
is listed? For some reason I thought it would be a 195.
My last project!
deniseO30 is offline
post #2 of 11 Old 02-22-2012
Large Member
Operating temp. of 170 to 185 - 160 sounds right.
http://www.ewmanchester.com/CalDocs/...s%20Manual.pdf
mdbee is offline
post #3 of 11 Old 02-22-2012 Thread Starter
One of None
deniseO30's Avatar
Thanks MD! I just thought they run hotter, or should.
My last project!
post #4 of 11 Old 02-22-2012
RichH's Avatar
If RAW water cooled - 150 deg. Tstat
If Fresh water (heat exchanger) then 180 Tstat.
With raw water cooling if the water temp. 'goes above' 155 carbonates will 'drop out' (precipitate) of the cooling water and quickly foul the cooling passages with (calcium, etc. carbonate) scale ... and that will require constant 'descaling' or 'pickle-ing' of the cooling system.
RichH is offline
post #5 of 11 Old 02-22-2012
BarryL's Avatar
Hey,
Two years ago my 'stat went bad. I installed a 180 stat from a Kubota dealer. It costs about $30 and was a perfect fit for my M25.
Barry
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #6 of 11 Old 02-22-2012 Thread Starter
One of None
deniseO30's Avatar
Barry, yes pretty sure it's bad on my engine too, takes forever to warm up, just like a car with a bad stat.
My last project!
post #7 of 11 Old 02-22-2012 Thread Starter
One of None
deniseO30's Avatar
Rich, yes it has a HeatEx.
My last project!
post #8 of 11 Old 02-22-2012
RichH's Avatar
Denise ...
Its a conundrum ... at greater than ~155 you get more scaling, and at well above 155 you continually develop 'black' rust (ferrous oxide) which is protective of cast iron hence longer 'corrosion' protection.
If you descale, you ultimately remove 'base metal' which shortens engine life ... unless you use an inhibited descaler (RydLyme, etc.).
If you run your engine 'long and hard', and use antifreeze with rust inhibiters when 'storing' the boat, a 150 T stat will be OK.
Since youre in the Del. River which is mostly 'fresh' near Trenton ... you might want to consider a 180 Tstat and simply do a routine 'descaling' with an inhibited descaler when the normal operating temp. rises ... 'profile' your engine with an IR thermometer and descale when the engine shows 'hot spots' above what you 'profile' when the engine was 'descaled'. Profile the 'whole' system - engine AND exhaust manifold AND injection elbow, etc. IR optical thermometers are cheap from Amazon, etc.
RichH is offline
post #9 of 11 Old 02-27-2012 Thread Starter
One of None
deniseO30's Avatar
I found a thermostat in the "junk" box on my boat! I think it's for the engine. 180 degree it's not as large as a automotive type. it's about 1.25 dia. I'm wondering now if my engine even has a tstat. I'll report back on this sometime in the next few weeks.
My last project!
post #10 of 11 Old 02-28-2012
Let us know how you get on, my 5424 is taking forever to warm up too.
MarkSF is offline
My Universal 5416 is which kubota engine?? deniseO30 Diesel 19 08-10-2014 01:57 PM
installing an automotive 80-90 amp alt on my Universal 5416? hellosailor Gear & Maintenance 14 05-17-2011 08:20 PM
Universal 5416 filters deniseO30 Gear & Maintenance 3 05-05-2009 10:50 AM
zinc in Universal 5416? wumhenry Gear & Maintenance 12 05-16-2007 04:01 PM
Transmission Needed For Univ 25xpb pgbaxter Gear & Maintenance 0 03-14-2007 03:02 PM
