Measuring Engine Exhaust Back Pressure - SailNet Community
post #1 of 9 Old 02-22-2012 Thread Starter
I have a fairly new rebuilt Yanmar 3GM30F and would like to know how to measure (I assume at the exhaust elbow) and would be the acceptable values of back pressure on this engine..
aa3jy is offline
post #2 of 9 Old 02-22-2012
To measure it you'd need a tapping point and a gauge - If your elbow has a threaded fitting and a plug that'd be easy enough.. otherwise you'd have to add one.
Why are you concerned? if the RW in the lift muffler is being ejected properly and the motor attains revs does it matter?
Faster is offline
post #3 of 9 Old 02-22-2012
the pointy end is the bow
erps's Avatar
I would expect that a marine application with a water lift muffler would have higher values than the ideal automotive application that's probably listed in the engine manual.
On the other hand, if one is experiencing low power, poor fuel economy, black exhaust, checking for a restriction in the exhaust system would help diagnose the problem. If that is a problem, it's most likely right at the exhaust mixing elbow, which can usually be removed and inspected without too much trouble.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #4 of 9 Old 02-22-2012 Thread Starter
The concern was brought to my attention from the engine re-manufacturer as to a possible "over fueling" issue due to possible inappropriate back pressure. The system was never tested thus the question as to what are the appropriate back pressure values....
aa3jy is offline
post #5 of 9 Old 02-22-2012
If your aqualift has a drain plug /valve to prevent back flow to engine if something goes bad with aunti siphon (mine's on a solenoid) it would be a good place to try a pressure gauge.The numbers might mean something to your agent. Many engines work hard simply because the breathing out hose is too small.
Capt Len is offline
post #6 of 9 Old 02-22-2012
erps's Avatar
how is this condition manifesting itself? How long has the problem been going on? Is the exhaust system different from the original set up? I would have some concerns that the engine re-manufacturer is diverting you attention elsewhere instead of addressing a possible problem with their motor.
FWIW, the 36 HP diesel on my boat sits pretty close to the waterline level and has to push the exhaust/water mix through approximately 15 feet of 1.5 inch ID hose. The motor is old and tired, but even this amount of lift and length in the exhaust isn't causing me to put out black smoke.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #7 of 9 Old 02-22-2012
Senior Slacker
SlowButSteady's Avatar
Just take the exhaust hose off of the elbow and look inside (the elbow; you may have to use a mirror), or stick your finger up inside and try to gauge how much build up there is. If the carbon build up looks like it's occluding more than 25%, or so, of the inside of the elbow then it's time to replace it.
I recently changed the elbow in my 2GM20. Not because the exhaust gases were being restricted, but because the water injection point (at the top of the elbow) had become so corroded and carboned up that the cooling water wouldn't flow through the system. (Hint: if you have the "U" type elbow, the hardest part of the whole job is getting the elbow/coupling/manifold to come apart. I let a diesel shop take care of that chore.)
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #8 of 9 Old 02-23-2012
The exhaust elbow is a violent place when the motor is running.
The exhaust will be pulsing like crazy and any guage on there will be fluctuation wildly, methinks.
Rockter is offline
post #9 of 9 Old 02-23-2012
Dog Ship's Avatar
I agree with "erps" in that your engine manufacturer is miss leading you from an internal engine problem and is blameing it on the exhaust. If your engine is getting too much fuel it will be pushing black smoke and it will be down on power. Your exhaust system has nothing to do with this.
As "Rockter" pointed out, measuring the exhaust pressure will be impossible as the exhaust pressure will fluctuate as water occasionally gets pushed out the tail pipe causeing the back pressure to increase momentarily.
If the engine is over fueling first check out the intake and it's filtre. Second, relace all fuel filtres. Third, check the fuel pressure to make sure it's within spec. If all of this checks out as good then I would suspect it is a bad injector or maybe three bad injectors.
Also you need to look at the condition of your fuel. Algea can grow in your fuel tank. This can cause serious issues with your fuel systems injectors and filtres.
My boat has a 3GM30F that was rebuilt 500 hrs ago. I swear by these engines and have never had a problem with them. I have used similar Yanmars in some of my equipment at work and they are a stellar engine.
Maintinance is key but I have seen over 10,000 hrs. put on these engines and they still fire up and run great all day long in some of the worst conditions.
Dog Ship is offline
Air cooled engine with wet exhaust? nsweeting Gear & Maintenance 40 01-21-2012 11:11 PM
Volvo Penta MD11C engine (oil pressure) wsgodlewski Gear & Maintenance 2 08-03-2011 08:22 AM
Automatic Low Oil Pressure engine shutdown pedcab Electrical Systems 6 03-23-2011 09:52 PM
Exhaust back pressure? downeast450 Gear & Maintenance 4 02-22-2010 04:57 AM
Engine Oil Pressure Problem msamelso Gear & Maintenance 2 02-20-2001 06:25 PM
