Adding an hour meter - SailNet Community
post #1 of 4 Old 02-26-2012 Thread Starter
There's no hour meter in my instrument panel. We track engine start and stop times and every few months go through them all and add up all the elapsed hours for maintenance but its a process that we could avoid.
Any recommendations on hour meters? What is the best place to wire it in? i.e. you can turn the ignition off and the engine will still run so that might not be the best place to connect the meter because you would miss running time.
Thanks.
extremo is offline
post #2 of 4 Old 02-26-2012
FSMike's Avatar
In some cases you can fry the alternator by turning off the key while the engine is running. Recommended to wire it into the ignition.
Sail Fast Live Slow
36' Solaris Sunstar catamaran
FSMike is offline
post #3 of 4 Old 02-27-2012
An engine hour meter is so rarely viewed, that it does not have to be on the instrument panel. I have one on an engine room bulkhead. An hour meter needs only to take its nominal 12 V positive supply off the ignition switch. All it needs then is an earth return to anywhere on the negative bus. Run the negative right to the battery negative terminal if you want.
Just splice a connection onto the positive side of the ignition switch, and route it to the hour meter, then an earth to the battery negative.
Rockter is offline
post #4 of 4 Old 02-27-2012
Hour meter is so p.c.. Didn't everyone call them "Hobbs meter" after the company that started or dominated it all?
hellosailor is offline
kiloWatt Hour meter -- will this work with 120v single phase??? Bene505 Electronics 4 01-13-2012 01:07 AM
installing an hour meter - no ignition Preserved Electrical Systems 18 07-29-2010 11:23 PM
Need to replace my tach with hour meter alan_21_us Gear & Maintenance 3 11-01-2008 07:38 AM
CS34 engine hour meter install? bestfriend CS Yachts 4 08-05-2008 04:24 PM
