universal 5416 problem and solution - SailNet Community
post #1 of 6 Old 03-22-2012 Thread Starter
I have a 1969 Columbia MKII with the Universal 5416. This was originally going to be a story to illicit help starting the engine but reading the entire sailnet diesel sub forum and countless others I've solved the problem.
I did just about everything wrong. Terrible battery maintenance, irregular maintenance of the engine, not running the engine, no primary fuel filter, old fuel left for years, attempting starts with the raw water seacock open and just about anything you could think of.
I did have a good excuse as I've had 2 kids in the last 5 years which has left very little time for the boat. But now I've learned my lesson, preventative maintenance saves time in the long run and I should have learned allot more about my boat engine after I inherited it.
On to the problems and solutions. It had been about 18 months since I sccessfuy started the engine and it took me that Long before I made the time to start trouble shooting. My batteries were probably 4 or 5 years old and with my terrible maintenance this was definately a culprit. But the very hot, basically melting ground cable was the first thing to replace plus I upped a gauge. Even with the old battery this made the engine turn over much stronger. Still it wouldn't catch. I was reading everything I could about diesel engines and learned about the importance of clean fuel. Upon inspection, another huge problem. The fuel pick up line had some serious growth and the 10gallon plastic tank had some major sludge. After trying to clean the tank for a few hours I decided to replace all the fuel lines, filter, and use a 5 gallon jug with clean fuel as a supply. Still not catching. It sounded to me like a fuel problem but I bought a new starting battery just to eliminate another variable. Still nothing. I began to worry about water in the engine because of my false starts and the muffler was filled with water so back pressure could have been a problem. I drained the water inspected the exhaust elbow and still not starting.
So now I'm really worried about water in the cylinders. I pulled the glow plugs and injectors to inspect them and see if here was anything ugly in the cylinder. Fortunately no fluid inside. The glow plug was definately not functioning and the injectors had so much build up I couldn't see the nozzle. Great, I finally had some evidence there was a problem with the fuel supply. Since my engine is based on the kubota l185 tractor new injectors and glow plugs were very reasonably priced. During the insalation I was bleading the low pressure side with high pressure side of the fuel lines off and I noticed the injector pump gurgling. Mind you I have a electric fuel pump so I wasn't turning the engine over at this point and from my limited understanding the mechanical injector pump shouldn't pass fuel unless the engine is being cranked. Although this seemed problematic and potentially very expensive I decided to continue replaceing the injectors. After multiple bleeds still no luck. Now I'm really nervous about the injector pump. I removed the inspection cover and sure enough the pin seemed sticky. I sprayed some carb cleaner and some sea foam in the fuel intake side. I removed the high pressure fuel lines turned the engine over and no more gurgling, alternating spurts just like I'd expect. Sweet.
So I reattached the high pressure lines, throughally bled the system and BINGO success. The engine turned over and seemed to run well. I was jumping up and down throwing my hands in the like a little kid. Just to give some perspective on my mood I left the house that day telling the wife it might be time to hire a mechanic.
Let this be a lesson to all that a little time every year can save you allot of grief.
Now I'm off to get a new tank, add a primary fuel filter, echo charger and a whole list of other stuff but thankfully not an engine rebuild.
Quick question. I think a 6 gallon tank would be adequate for my needs and allow me to keep the tank topped off easily does this seem like a sound plan? any suggestions on a tank?
Thanks for listenting to my rant.
More questions to come.
brian
bmorena is offline
post #2 of 6 Old 03-22-2012
One of None
deniseO30's Avatar
Re: universal 5416 problem and solution
Hey Brian welcome to Sailnet! I also have the same engine. So glad you got it working too! We replaced the tank on my boat, took out the aluminum and used a Moeller 19 gal that I could actually remove by myself anytime I'd have a fancy to.. 6 gal would be small if your motoring more then a couple of days without spare fuel containers and or Marina stops. It does sip fuel though, the 5416, water, clean fuel, and air is what it needs and wants!
My last project!
deniseO30 is offline
post #3 of 6 Old 03-22-2012 Thread Starter
Hi Denise,
Thanks for the reply. My logic for 6 gallon is that we don't motor much so having a small tank would be easier to keep topped off and clean. I can always keep an extra 5 gallon for any longer trips. Unfortunately I haven't found a 6 gallon tank with a diesel return port.
B
bmorena is offline
post #4 of 6 Old 03-24-2012
JimsCAL's Avatar
I assume you are planning to use a 6 gallon portable outboard tank. Yes, not return connection, but you could add one. A MUCH better solution would be an inexpensive plastic fuel tank designed for below deck installation. Something like 10 gallons or so would work fine.
JimsCAL is offline
post #5 of 6 Old 03-24-2012 Thread Starter
Yeah jimscal, I came to the same conclusion which I think makes allot more sense.
bmorena is offline
post #6 of 6 Old 03-24-2012
bmorena :
There is nothing a motor appreciates more than regular exercise.
Clean fuel, clean oil, and some exercise.
They will reward it with reliability, lots of times anyway.
I find that a pressurised fuel system helps enormously. I used one of those Stewart-Warner 5 psi fuel delivery pumps.
Air cannot leak in with one of those in there.
Rockter is offline
Tags
diesel , starting problems , universal 5416
My Universal 5416 is which kubota engine?? deniseO30 Diesel 19 08-10-2014 01:57 PM
installing an automotive 80-90 amp alt on my Universal 5416? hellosailor Gear & Maintenance 14 05-17-2011 08:20 PM
Universal 5416 / M-20 - Performance Survey Groven Gear & Maintenance 0 09-03-2009 09:22 AM
Universal 5416 filters deniseO30 Gear & Maintenance 3 05-05-2009 10:50 AM
zinc in Universal 5416? wumhenry Gear & Maintenance 12 05-16-2007 04:01 PM
