Universal 5411 or M15 - SailNet Community
post #1 of 7 Old 04-21-2012 Thread Starter
I'm a bit confused when It comes to the Universal engine in my 1984 N-28 II. The original survey 10 years ago had the engine listed as a 5411. The dip stick is labeled Z-500 and its antifreeze cooled so its my understanding the engine is a M15 (16 HP, 45 in^3) not the 5411 (11 hp, 31 in^3). Are there other ways to tell the difference. (still cant up load pictures)
Donaldpeter is offline
post #2 of 7 Old 04-21-2012
One of None
deniseO30's Avatar
Re: Universal 5411 or M15
5416 was the universal 16 hp engine Donald. I have one in my boat. it was the Z-750 kubota engine used in the kubota L-185 tractor
The Z500 seems to be this.
Engine:
Type: Kubota Z500-1A
Fuel: diesel
Aspiration: natural
Cylinders: 2
Valves: -unknown-
Bore/Stroke: 2.625x2.75 inches [67 x 70 mm]
Displacement: 31 ci [0.5 L]
Power: 12 hp [8.9 kW]
Cooling: liquid
Coolant: 3.2 qts [3.0 L]
Compression: -unknown-
Rated RPMs: 3000
Starter volts: 12
Starter power: 1.1 hp [0.8 kW]
Oil capacity: 2.4 qts [2.3 L]
My last project!
deniseO30 is offline
post #3 of 7 Old 04-21-2012
JimsCAL's Avatar
The 5411 and M15 are essentially the same engine based on the Kubota Z-500 industrial engine. The 5411 became the M15 at the end of its production run. If yours is fresh water cooled, not raw water cooled, i.e it has a heat exchanger, it was probably converted at some point.
JimsCAL is offline
post #4 of 7 Old 05-06-2012 Thread Starter
This Universal Engine History is the web site I was referring to in my original post. It says "In 1977 the Model 5411 was introduced. It was a 31 cu in, 2 cylinder raw water cooled diesel producing 11 hp @ ? rpm, based on the Kubota Z-500 block, and fitted with a Hurth HBW-50 marine transmission." and "In 1982 the Model 5411 was replaced by the Model M15, a 45 cu in, 16 hp, 2 cylinder, fresh-water-cooled, based on the Kubota Z-500 block and fitted with a Hurth HBW-50 marine transmission." Is this web site in error?
post #5 of 7 Old 05-07-2012
JimsCAL's Avatar
Yes, that site is incorrect. Looks like they did some copying/pasting and mixed things up. Here's a link to a similar history. Note the similarity to the wording. And the slightly different commentary about the M15.
History of the Universal Motor Company 4
The Kubota engine number your engine is based on should be stamped on the oil dipstick. The 5411/M15 is a Kubota Z-500.
JimsCAL is offline
post #6 of 7 Old 06-01-2012 Thread Starter
Thanks Jim, I almost forgot why I cared, then I remembered I was considering replacing the old three engine mounts but I needed to know the proper engine weight which leads me back to which engine I have. Thanks again.
post #7 of 7 Old 06-01-2012
One of None
deniseO30's Avatar
Engine:
Fuel: diesel
Aspiration: natural
Cylinders: 2
Valves: -unknown-
Cooling: liquid
Rated RPMs: 3000
Starter volts: 12
right... your welcome
My last project!
Last edited by deniseO30; 06-01-2012 at 08:43 PM. Reason: It's tough being invisable
oil pressure light M-5411 Universal jimd333sail Diesel 3 09-12-2011 09:36 AM
Overheating Universal 5411 JohnBassett Gear & Maintenance 20 05-20-2009 11:54 AM
Universal 5411 gbertelsen Gear & Maintenance 2 05-12-2009 10:56 PM
Universal 5411 Oil Change saurav16 Gear & Maintenance 10 10-01-2007 07:16 PM
Universal diesel 5411 rmiille Gear & Maintenance 1 12-30-2001 06:01 AM
