Diesel Engine Replacement - SailNet Community
 5Likes
post #1 of 13 Old 04-22-2012 Thread Starter
I have a 39'9' 1983 Irwin sloop and need to replace the engine. I plan to hoist the engine out of its bay with a portable winch using the boom (engine on a sloop is directly under the end of the boom) with the main halyard linked for additional weight support. The engine weighs 650lbs and the question is will the boom, support lines and mast support that kind of weight. Has anyone had experience lifting an engine using that technique? Advice appreciated.
Lem
lemmystic is offline
post #2 of 13 Old 04-23-2012
JimsCAL's Avatar
Re: Diesel Engine Replacement
I did it that way a couple of years ago on my previous boat, but the engine was only 250 lbs. If your rig is solid, it should support your heavier engine, but I would still be nervous. You can always rent a portable crane.
JimsCAL is offline
post #3 of 13 Old 04-23-2012 Thread Starter
Thanks
post #4 of 13 Old 04-23-2012
Over Hill Sailing Club
smurphny's Avatar
Maybe rig up something other than a topping lift which was not designed to lift that much weight. Use the halyard attached opposite the load point? To take pressure off the mast at the gooseneck, maybe tie back to something. The gooseneck itself should be ok if it's rugged enough.
Faster likes this.
smurphny is offline
post #5 of 13 Old 04-23-2012
Señor Member
PorFin's Avatar
Lem,
I'd recommend you think through all the steps before you start -- not suggesting that you haven't.
Once you get the engine clear of the interior of the boat, how are you going to get it over the side? Will the boom (with engine slung under) be able to swing outboard far enough to allow you to drop the block onto the dock or ground?
If you are going to need to hire a crane or lift anyway, it may be easier, cheaper, and less stressful to just use it for the whole job.
jrd22 likes this.
PorFin is offline
post #6 of 13 Old 04-23-2012
You can drop a lot of weight by disassembling alternator, heat exchanger, starter, manifold, even the cyl head...all sorts of odds and sods prior to lifting it out.. it also makes for a smaller package, easier to manoeuvre out the hatch.
arf145, smurphny and SloopJonB like this.
Faster is offline
post #7 of 13 Old 04-23-2012
smurphny's Avatar
Yes, maybe even the gear box. My Yanmar 3GM only weighs half the weight of the OP's motor. I wonder what kind?
smurphny is offline
post #8 of 13 Old 04-23-2012 Thread Starter
Thanks to all for the feedback. In reply to the last post the engine is a 1983 yanmar 3Qm30 Lem
post #9 of 13 Old 04-23-2012
JimsCAL's Avatar
Another item to check is will the block and tackle or chain fall be long enough to lower the engine all the way to ground after you get it up and out the then swung over the side. It's a long way down and the typical rig isn't long enough. Found that out the hard way.
JimsCAL is offline
post #10 of 13 Old 04-24-2012 Thread Starter
On reinstalling my yanmar engine, any tips or guidance on aligning the gearbox and the shaft? Thanks Lem
462 Engine Replacement jb1842 Morgan 7 09-07-2010 02:13 PM
Diesel Engine Replacement (Yanmar 2QM20) - Recommendations westannapoliscrew Diesel 2 04-07-2010 04:43 PM
Diesel Engine Replacement - Yanmar 2QM20 westannapoliscrew Diesel 0 03-30-2010 04:45 AM
Engine Replacement Helimech Gear & Maintenance 3 12-21-2005 11:10 AM
Engine Replacement Dan Dickison Gear and Maintenance Articles 0 10-27-2001 08:00 PM
