Yanmar 3GMF Overheating - Page 2 - SailNet Community
Chat
Advertise Here
Go Back   SailNet Community > On Board > Gear & Maintenance > Engines > Diesel
Like Tree1Likes
Old 04-25-2012
gordofloats's Avatar
gordofloats is on a distinguished road
Re: Yanmar 3GMF Overheating
Originally Posted by smurphny View Post
4000 rpm is very high for this engine. I have a 3GMF and run it at less than 3000, usually around 2700 which seems to be its sweet spot at hull speed which for me is around 6.5K. ...
You are right, I meant full at 3000. A few months on the hard and the memory goes a little. Last season I could motor for hours at around 5.5K (she has a hull speed of 7K) but when I pushed her beyond that the alarm would go off after about 10 minutes. The season before I had no trouble motoring all day at hull speed.
So I was at the yard today with these suggestions in hand and made a few discoveries. The first is that the coolant I used was supposed to be diluted and I hadn't - not pleased with myself on that count. The other is that the belt for my raw water pump was cracked and loose. I am still going to flush out the coolant system and check the mixing elbow as per the recommendations here and believe that my engine will be back to her full potential this season. Thank you again for the responses. This forum is indispensable.
Reply With Quote Quick reply to this message Share with Facebook
  #12
Old 04-26-2012
Shortman's Avatar
Shortman is on a distinguished road
#1 I'd check water flow out exhaust pipe, easiest way to see if you're obstructed.
Mixing elbow is another good one. they say they need to be changed every 4-5 years which is probably too frequent but they do rust up inside.
I too have a 3GMF & sweet spot is 2800 for my hull.
Coolant may not be proper but I believe the issues with that would be levels of corrosion protection not hot & cold.
Loose belt would certainly do it.
  #13
Old 04-26-2012
Today I checked the mixing elbow - a little rusty but not clogged - cleaned the coolant system with Prestone Super Flush - pretty gungy - replaced the RW pump belt and replaced the coolant with the proper mix and ran the motor for for a good hour with the RW intake in a bucket with a hose. I'll update this post once she's back in the water and I can see if we've solved it.
I also happened to look in my Don Casey Bible (don't ask me why I didn't do this before I tackled the coolant) and according to Him full strength coolant gels up at high temperatures and clogs the hoses causing overheating - thought I should post that.
  #14
Old 05-18-2012
Sailingking22 is on a distinguished road
Did you get the overheating solved? Sounds like you had several items working against you, but mainly the coolant change. What is the correct tempature the Yanmar Diesel should operate at? I was constantly cleaning my mixing elbow to keep the engine cooler. It did not run the past two months and now that it is running again I wonder if it has rusted on the inside again. Last cleaning, I took it off and soaked it in a bucket overnight full of cleaning solvents. Maybe I'll do that again. Currently, it runs about 250 degrees after an hour....too hot to leave your hand on so I kill it when this happens. Mine is a YSM 12 so it is cooled by raw water. Impeller sprays out great on the input side....I know cause the line slips off from time to time. Most likely another clog. I'll follow the advice given here and post an update.
  #15
Old 05-18-2012
Full strength antifreeze also actually 'loses' its freeze protection (ie the freezing point comes back up from the 'low' peak at about 60% concentration.)
Something to be aware of for your truck up north, maybe not so critical in a boat but still...
  #16
Old 05-18-2012
So far so good. I'm pretty confident that my issue was coolant mix and a loose impeller belt. As far as it's actual running temperature, I don't know how to get that figure. I have a temperature alarm but no thermometer. Is there a handheld instrument that we should have on board?
  #17
Old 05-18-2012
asdf38's Avatar
asdf38 is on a distinguished road
An infared thermomitor is a really handy tool to have. Just shoot it at the engine (pick a spot on the block) and you can get a good sense of the temperature.
Amazon.com: Raytek MT4 Non-contact Mini Infrared Thermometer: Automotive Amazon.com: Raytek MT4 Non-contact Mini Infrared Thermometer: Automotive
I just wanted to add a couple things in regards to things that were said:
1) Yes this forum is a tremendous resource, it's great you came back to give the conclusion. It's a pet peeve of mine when people don't. I routinely do google searches for "blah blah site:sailnet.com" (if you don't know this trick you should try it) which is great at digging out old threads.
2) It's really really hard to judge the amount of water coming out of the tailpipe. I dealt with overheating on my 1gm10 (google search "overheating 1gm10" and my thread will come up) which turned out to be a lodged impeller blade from the previous season. But there was seemingly plenty of water coming out and after it was fixed the difference was still hard to judge.
  #18
Old 05-18-2012
JimsCAL's Avatar
JimsCAL is on a distinguished road
Normal cooling water temps for raw water cooled engines is about 140F or so and for fresh water cooled engines its 160-180F. What temp are you saying is 250F? MUCH too high for the cooling water!
  #19
Old 05-18-2012
dabnis is on a distinguished road
I have read that full strength coolant does not dissipate heat as well as 50% mix. Changing to 50% may be an easy fix? Let us know how it comes out.
Paul T
  #20
Old 05-22-2012
dfsdghsdhsd is on a distinguished road
I agree with smurfny, 4000 rpm is too high for the 3GMF for any length of time. I never go over 3000 on mine and the boat won't go any faster anyway.
If you have flushed your coolant, when you fill it back up, you will need to run the engine for a few minutes, then stop it and add coolant and repeat as necessary. That engine takes a lot of coolant. The problem with the mixing elbow that everyone mentioned is usually due to running the engine at anchor to charge the battery. When the engine runs under load, it should not be a problem. You may want to check that the elbow is free of obstruction at the end of the season, though..
You may post attachments
You may edit your posts
Yanmar 3GMF: Mystery Drop in RPMs AndrewMcG Diesel 11 08-09-2011 06:02 PM
Yanmar 2 qm 15 overheating mystery NickAllinson Gear & Maintenance 9 06-26-2011 11:39 PM
Yanmar 3GMF py26129 Gear & Maintenance 2 06-15-2011 02:59 PM
Yanmar 3HN35F OVERHEATING kjango Gear & Maintenance 11 05-26-2009 11:29 PM
Yanmar 2GM overheating Northeaster Gear & Maintenance 11 07-18-2007 04:07 PM
Copyright ©2000 - 2015, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
The SailNet.com store is owned and operated by a company independent of the SailNet.com forum. You are now leaving the SailNet forum. Click OK to continue or Cancel to return to the SailNet forum.
