Fuel Lift Pump Questions - SailNet Community
post #1 of 11 Old 04-25-2012 Thread Starter
leogallant's Avatar
On our 1973 Newport Mark II, we have a Vetus M3.10
What I can't find is a lift pump to bleed the lines after a service.
If you look at this photo of the engine, at the very bottom right, you'll see what I'm guessing is an electric fuel lift pump? Looks like a little black coffee can, with fuel lines. The former owners said to turn on the Blower switch on the DC panel before starting engine. When we turn on "Blower", this little coffee can is what makes the noise as if a little motor is running.
If this is indeed the fuel pump, I'm wondering what the proper procedure is for bleeding the lines?
Leo
Journey to Charleston on Ubiquitous
Steve's Ubiquitous Blog
leogallant is offline
post #2 of 11 Old 04-25-2012
jsaronson's Avatar
Isn't that an electric lift pump on the bottom right of the photo? I don't think they are bled.
Atlantis
Hylas 44
Annapolis
jsaronson is offline
post #3 of 11 Old 04-25-2012
Maine Member
BELLATRIX1965's Avatar
Re: Fuel Lift Pump Questions
Yup, that looks like an electric fuel lift pump.
2 things: 1st: I would strongly suggest that you re-label that switch to indicate the proper device that it powers; and 2nd: You can bleed that fuel filter (and the lift pump/hoses) via the vent screw on top of the filter assembly (it looks like a bolt) - just make sure to have two people (one to operate the switch and shut it off when you get fuel out the vent) and have a drip pan / diapers to catch any fuel spilled in the process. Best to keep the fuel OUT of the bilge!
BELLATRIX1965 is offline
post #4 of 11 Old 04-25-2012 Thread Starter
leogallant's Avatar
That's what we're thinking. I had hear that too about bleeding if there is an electric one. Just wanting to make sure that it really is an electric pump.
Leo
post #5 of 11 Old 04-25-2012 Thread Starter
leogallant's Avatar
That makes sense, thanks!
Leo
post #6 of 11 Old 04-26-2012 Thread Starter
leogallant's Avatar
So then, seeing there isn't actually a blower installed in the engine compartment, should i consider adding one? This is a diesel engine, and as you can see in the former picture, it is not a sealed off engine compartment.
Leo
post #7 of 11 Old 04-26-2012
jsaronson's Avatar
No need with a diesel. Vapors don't collect and ignite like gas.
Atlantis
Hylas 44
Annapolis
post #8 of 11 Old 04-26-2012 Thread Starter
leogallant's Avatar
That's what I thought, but wanted to double check. Thanks so much!
Leo
post #9 of 11 Old 05-03-2012
Stu Jackson's Avatar
1. Yup, that looks like an electric fuel lift pump.
2. - just make sure to have two people (one to operate the switch and shut it off when you get fuel out the vent) and have a drip pan / diapers to catch any fuel spilled in the process. Best to keep the fuel OUT of the bilge!
1. Fuel lines to it and wires to it. Hmm, could be a giveaway...
2. Here's an idea to avoid needing two people: splice into the power wire or the ground of the lift pump, and add a simple toggle switch inside the engine compartment. Label it "Fuel Pump Shutoff" and when the fuel starts coming out of the hole when you replace the secondary filter on the engine, just shut it off down there. Of course, you can use that second person to get you a beer, since you won't spill a drop!
Nice oil filter, BTW, great to see one in the right orientation so it won't drip all over when you remove it.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #10 of 11 Old 05-03-2012
A little more info on electric pumps:
The Diesel Page, Electric Lift Pump and Racor Filter installation
Paul T
dabnis is offline
Yanmar 2GM20F lift pump fuel line size arf145 Diesel 3 05-05-2013 08:30 AM
Fuel Pump HorizonHunter Atomic 4 4 08-05-2010 04:50 PM
Fuel pump Questions nereussailor Gear & Maintenance 3 08-09-2009 10:43 PM
Fuel Pump puff6022 Gear & Maintenance 4 11-28-2008 04:07 PM
Fuel pump justified Gear & Maintenance 5 06-18-2007 07:25 PM
