cordless drill and socket "starter" - SailNet Community
 6Likes
post #1 of 38 Old 05-01-2012 Thread Starter
One of None
deniseO30's Avatar
Reading Roger Long's adventures on sailboat owners has me wondering about engine starting if the starter quits. I know most of us agree that crank starting a diesel is out of the question. Anyway, I got to thinking Some of the cordless drills are pretty beefy, so if you had access to the crankshaft bolt on the front of your engine. and you use the compression release lever. Would you try that? I know there's broken wrist potential there...
jus thnkn
My last project!
deniseO30 is offline
post #2 of 38 Old 05-01-2012
BarryL's Avatar
Re: cordless drill and socket "starter"
Hey,
There is no way a drill is going to get a diesel going. Maybe an impact wrench or air gun that generated 500 ft lb of torque, but no drill is going to do that.
Barry
deniseO30 likes this.
Barry Lenoble
Deep Blue C, 2002 C&C 110
Mt. Sinai, NY
BarryL is offline
post #3 of 38 Old 05-01-2012 Thread Starter
One of None
deniseO30's Avatar
there are cordless impact drivers too Barry, some of the new cordless tools are pretty beefy too. Maybe smaller engines ? This is just curiosity on my part.
My last project!
post #4 of 38 Old 05-01-2012
So the story goes, a broker I know claims to have started the 100hp diesel in a sister ship to my boat by wrapping a spare halyard around the flywheel pulley and pulling it with the hi speed cabin top electric winch.
I wasn't there, but this guy is not known for story telling and seemed fairly surprised it worked himself.
Jeanneau 54DS
Minnewaska is offline
post #5 of 38 Old 05-01-2012
As I think about it, all starter motors are cordless.
Jeanneau 54DS
post #6 of 38 Old 05-01-2012
Seņor Member
ottos's Avatar
Sounds similar to a story I've heard (and only partially remember) - Salty Sailor is off shore, and finds his starter wont go, for whatever reason. SS makes fast a line on the boom and takes a few wraps around an engine pulley. Gybe ho! and problem solved.
ottos is offline
post #7 of 38 Old 05-01-2012
Old as Dirt!
svHyLyte's Avatar
jus thnkn
Actually, it's a pretty creative idea. With the compression released, the Milwaukee drill I have should be able to spin up a fairly sizable engine, although it might take a few minutes to get up to a good speed. If one had a ratchet socket on the drive so the engine could spin freely, just in case it started before one could withdraw the socket/drill, there's no reason why it couldn't work.
There was a case some years ago where one of the Globe competitors lost his starter and was able to get his engine going once a day for charging by wrapping a line around the front pulley and then connecting it to his centered boom. He's turn broad-side to the wind, release his main sheet and the speed of the boom running out spun-up and started his engine.
Denise's idea really has some merit.
FWIW...
svHyLyte is offline
post #8 of 38 Old 05-01-2012
Senior Slacker
SlowButSteady's Avatar
Those cordless "impact drivers" are pretty wimpy. Look at the specs on one of them. A pneumatic impact wrench will list its torque in foot-pounds; a cordless toy will list its torque in inch-pounds. I doubt that even a good-sized pneumatic impact wrench could start even the smallest diesel. A cordless wouldn't stand a chance. And that isn't taking the damage caused by the impacting action (the engine flywheel just isn't designed for the rat-a-tatta-tatta of an impact device).
A good-sized electric drill might be able to turn a diesel over fast enough to start it. But you would need a 15 or 20 amp/120V power source to feed it.
EDIT:
I suppose you could use a cordless drill to get the engine spinning with the decompression valves open and then start one cylinder. You would probably need a pretty beefy cordless. The starter motor on my 2GM20 isn't all that big, but it draws a lot of amps. I doubt a cordless drill's battery would last very long in such an application. I still wouldn't try to start the engine with an impact tool.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
post #9 of 38 Old 05-01-2012
Denise, I've met some engines that had hand crank factory-shipped with the engine, and can only say that grown men wasted their time trying to use any of them.
Ropes on the flywheel? What, cut off the normal alternator belt to fit it in the groove?
I think I'd rather carry a spare starter, or wait for the wind. There's a word for a diesel that isn't perfectly well-behaved and mannered: Scrapyard!
hellosailor is offline
post #10 of 38 Old 05-01-2012
Senior Slacker
Originally Posted by hellosailor View Post
...There's a word for a diesel that isn't perfectly well-behaved and mannered: Scrapyard!
Now, now. Diesel's should be lovingly tended and pampered. Talked to in a calm, soothing tone; and then only to offer praise and encouragement. However, you should also store the biggest ball-peen hammer you can swing right next to the engine -- it will get the hint.
Tanzer 26 - "Starter" or "Build like a tank" asdf38 Boat Review and Purchase Forum 5 09-24-2016 08:09 PM
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
Re: Starter, "I" feel/thin it needs to be Marine NewsReader Mass Bay Sailors 0 03-25-2007 06:15 PM
Starter, "I" feel/thin it needs to be Marine NewsReader Mass Bay Sailors 0 03-25-2007 01:15 PM
C270 Main Sail "stack Pack", Quick Cover", "lazy Bag" Install randy22556 Catalina 1 02-28-2007 11:53 AM
