Raw Water Pump Rust/Corrosion - SailNet Community
post #1 of 1 Old 05-04-2012 Thread Starter
Hey all-
My Sherwood Raw Water pump (Engine is Universal M4-30a) is showing signs of corrosion. Late last season, I noticed a small bit of water coming from the weep hole as well as some accompanying light rust and corrosion. I had the pump looked at and changed out seals etc...When checking out the engine last week at splash, I noticed some much heavier corrosion (typical greening, but also white, salty looking scale). I ran the engine under load at the dock, did not notice any drips, and temperature stayed within tolerance. But the rust/corrosion has me worried. How much rust/corrosion is too much? At what point is peace of mind worth just replacing the pump rather than rebuilding existing? Any thoughts appreciated.
Thanks,
pk
pk5352 is offline
Brown Rust water in bilge althedieselguy Gear & Maintenance 1 06-05-2011 08:17 PM
Water Pump? brianontheroad Gear & Maintenance 2 02-10-2009 09:34 PM
water pump Ariel1989 Gear & Maintenance 5 05-26-2008 10:15 PM
Rust and Corrosion. wind_magic Gear & Maintenance 4 06-17-2007 11:13 PM
2GM Raw Water Pump KenD Gear & Maintenance 1 05-10-2007 07:28 PM
