lube oil bypass filter - SailNet Community
post #1 of 5 Old 05-06-2012 Thread Starter
SV Skalliwag #141
brokesailor's Avatar
My Vovo Penta 2003 has this bypass filter installed by the PO. It actually has a roll of toilet paper inside as filter media. Anyway it is leaking out of the top wingnut seal. Bilge full of oil. I looked up the company on the Internet and I guess they don't make these anymore. What do I do?
brokesailor is offline
post #2 of 5 Old 05-07-2012
Re: lube oil bypass filter
Can you take a picture of it and post it here?
Rockter is offline
post #3 of 5 Old 05-07-2012
Sounds like it might be very old? Is it the only filter? If so suggest replacing it with a full flow spin on type of arrangement that has a by-pass feature if the filter becomes plugged. If it is a full time by-pass filter only part of the oil is being filtered.
Paul T
dabnis is offline
post #4 of 5 Old 05-08-2012 Thread Starter
SV Skalliwag #141
Can't send picture, no way to download to laptop on the boat.
A mechanic looked at it and we will be removing it. Thee rreturn line will be capped off at the block. The supply line is going to be fitted with a local oil pressure gauge.
Still haven't figured out how to get all that oil out of the bilge. I bought some WM oil absorbers but they are not doing the job.
post #5 of 5 Old 05-08-2012
Haven't seen one in decades but the TP filters I remember were from the Franz company which rightfully should be out of biz. In a quick search I found a company with a copycat type name which lists all the usual hype for those filters.
Frantz Oil Filters
"Just call me TB"
capttb is offline
Sail lube / wax Scott Vickery Gear & Maintenance 2 08-29-2011 01:50 PM
What is a bypass-type circuit (coolant)? pegasus1457 Diesel 6 08-03-2010 03:44 PM
Universal diesel Kobuta oil filter is a Fram PH3593A looking for diesel fuel filter dave hirsh Diesel 4 06-07-2010 09:01 AM
Racor fuel filter filter guage Grumpymx Gear & Maintenance 5 08-26-2008 08:10 PM
