Volvo Penta 2003 Trans oil? - SailNet Community
post #1 of 6 Old 05-14-2012 Thread Starter
Does anyone know what is the proper oil to use in the transmission? The engine uses 15/40 wt. Do I use that in the transmission also. The manuals I've seen online really don't address it.
Any help is very appreciated!
Brian
DoubleEnder is offline
post #2 of 6 Old 05-16-2012
Re: Volvo Penta 2003 Trans oil?
The earlier model Volvo MD17 C has 80W/90 gear oil in the gearbox.
It may be the same.
Rockter is offline
post #3 of 6 Old 05-17-2012
Yikes. Get the service manual for your transmission/reversing gear! You are right that the operating manuals don't do a good job with this. My Volvo TAMD31S-MS25L takes Dextron II/III. This is not something you want to get wrong.
Jeanneau 54DS
Minnewaska is offline
post #4 of 6 Old 05-17-2012 Thread Starter
Thanks guys. I'll figure it out. Going down in 3 weeks to get the boat and sail her home. Va. to Ma. I'll confirm then the trans. model and get the right stuff before leaving. A sniff test will tell me if its dextron vs oil.
Cheers,
Brian
post #5 of 6 Old 05-17-2012
You might also want to refer to Volvo Penta Service Bulletins. Service Bulletin Group 44-1 Number 85 Version 2 changed the recommendation for oil quality in S-drives from ATF to SAE 15W-40.
TejasSailer is offline
post #6 of 6 Old 06-11-2012
PhilipStevens's Avatar
Send a message via Skype™ to PhilipStevens
I've got a VP2003 in our boat, and can confirm that the MS2 gearbox takes the same oil as the engine.
I had the engine overhauled a couple of years ago, and the engineer (who knew all there is of the VP2000 series) said that it does take 15W-40 lub oil.
While on the subject of the gearbox, you may want to read this about the splines.
Here is another link to different drives oil.
regards,
Philip.
PhilipStevens is offline
Volvo Model 2003 Hot Water Connection Allegro1 Gear & Maintenance 4 03-17-2010 08:37 PM
Volvo 2003 gearbox j34035 Diesel 1 01-24-2010 05:15 AM
Winterizing Volvo 2003 moonie5961 Diesel 2 12-04-2009 08:10 AM
Volvo Penta 2003 to 2003T fawcettm Gear & Maintenance 0 05-05-2009 09:44 AM
Leaky transmission Volvo Penta 2003 ekhar Gear & Maintenance 0 08-15-2002 05:54 PM
