Alt Bracket Turnbuckle? - SailNet Community
post #1 of 2 Old 05-15-2012 Thread Starter
Seņor Member
PorFin's Avatar
Hey, gearheads -- I need a little advice.
I'm going to try and improve my life a tad.
I've got a 100A Balmar alternator (912-100D) mounted on a Perkins 4-108M. The only recurring complaint I've had with this set up is that in order to adjust the belt tension, I've got to get behind the face of the alternator with a 9/16 wrench to loosen the lock/dog bolt (being very careful not to short the wrench from the block to one of the positive output studs.) Not as difficult as some other access challenges, but aggravating all the same. I'd live with it, but now...
The swing arm of the alternator bracket has finally chaffed through the coolant crossover pipe (it takes the freshwater from the starboard side of the block across the front of the engine and up to the heat exchanger/exhaust manifold.) That's going out for repair.
My latest brain fart is that a turnbuckle equipped with rod ends would make adjustment easier and probably eliminate my chafe issues.
Can anyone give me an idea of how beefy I need to go to make this set-up work? How much of a load on the turnbuckle are we talking about here?
PorFin is offline
post #2 of 2 Old 05-16-2012 Thread Starter
Seņor Member
PorFin's Avatar
Bump
Anyone? Anyone?
Buehler? Beuhler?
PorFin is offline
Turnbuckle usage brucedtyler Gear & Maintenance 3 02-27-2011 04:47 PM
Strange Turnbuckle mitiempo Gear & Maintenance 8 09-04-2010 10:34 AM
Have you ever seen a turnbuckle fail? 2Sheets2Wind Gear & Maintenance 13 11-20-2009 08:10 PM
Short turnbuckle brak Gear & Maintenance 6 09-01-2007 12:24 AM
Turnbuckle help! kazubb Gear & Maintenance 2 05-21-2007 10:19 PM
