Yanmar yms12 wont idle - SailNet Community
post #1 of 19 Old 05-15-2012 Thread Starter
s/v Ubiquitous
Domknotty's Avatar
Send a message via Yahoo to Domknotty
Help, I just refurbished (cleaned like new) the fuel tank, replaced the filters, bench tested the fuel pump...works. No leaks that I can detect. Cranks like a jem at 1/4 throttle, to keep it running I have to rev it a little and can back it to 1/4 - 1/2 throttle and will purr but any lower it chokes out. Checked to make sure choke is open but still wont idle. ideas?
Bill Brown
Pensacola Florida
1972 Morgan 35
The good ship Ubiquitous
Blog Addy
Domknotty is offline
post #2 of 19 Old 05-15-2012
JimsCAL's Avatar
Re: Yanmar yms12 wont idle
At what RPM does it stall? There is an adjustment on the throttle linkage of most diesels to set the idle speed. Note that diesels don't have a choke.
JimsCAL is offline
post #3 of 19 Old 05-15-2012 Thread Starter
s/v Ubiquitous
Domknotty's Avatar
I have no rpm gauge but if a idling motor runs at 600rpm and full throttle is around 3500 I would say it chokes out (for lack of better words) at about 1000-1200 rpm, ALMOST slow but above idle. If I catch it I can give full throttle and keep it running, if im late it dies with a chug.
Bill Brown
Pensacola Florida
1972 Morgan 35
Blog Addy
post #4 of 19 Old 05-15-2012
that's not a choke
Make sure the fuel shut off is not engaged and the cable moves freely. Sounds like it is not getting enough fuel.
KBuckley is offline
post #5 of 19 Old 05-16-2012
JimsCAL's Avatar
Does sound like the fuel is getting cut off early if it indeed won't run below 1000-1200 RPM. Is your engine stop a separate control or engaged by moving the throttle past idle? If the the latter, it could just be a simple adjustment or a sticking cable like KBuckley suggests.
JimsCAL is offline
post #6 of 19 Old 05-16-2012 Thread Starter
s/v Ubiquitous
Domknotty's Avatar
due to a broken choke cable I am hopping from cabin to cockpit to adjust the choke and hit the engine kill lever.
Could it be my fuel pump, when I took it off I bench tested it and got a good flow by pumping the lever with no sign of leakage.
Another note, before cleaning the fuel tank it did idel, like a charm actually, but did not like going into higher rpm's. Maybe this will help.
Bill Brown
Pensacola Florida
1972 Morgan 35
Blog Addy
post #7 of 19 Old 05-16-2012 Thread Starter
s/v Ubiquitous
Domknotty's Avatar
also, if I put an electric fuel pump inline before the fuel filters, would it blow the diaphragm out of the manual fuel pump or should I bypass the manual fuel pump all together? Just an idea, I would really rather fix it then throw money at it.
Bill Brown
Pensacola Florida
1972 Morgan 35
Blog Addy
post #8 of 19 Old 05-16-2012
Over Hill Sailing Club
smurphny's Avatar
A diesel with a choke? Did you find all the air bleeders? Sometimes they are not easy to find. Bleed the injectors right at the banjo fittings if all else fails.
smurphny is offline
post #9 of 19 Old 05-16-2012
If it didn't pull max RPM's under load before could be dirty or over pitched prop? Maybe a clogged vent? or fuel pickup tube screen in the tank? No idle after cleaning, maybe some debris broken loose and partially blocking passages somewhere? could be hard to find. Air leak somewhere? A pressure pump would probably show where:
The Diesel Page, Electric Lift Pump and Racor Filter installation
Try disconnecting all the control cables and manually open throttle
Check all connections, make sure there is no air spaces in filters.
You could by-pass the tank with a seperate fuel source?
It appears that something happened after you cleaned the tank?
If all else fails you might take the pump/governor assembly to a shop for cleaning and re-calibrating. If so make a mark on the block and pump housing for easy re-install. Let us know what you find.
Paul T
dabnis is offline
post #10 of 19 Old 05-16-2012
Please describe what you are calling the "choke". There should not be a choke on a diesel....
Thanks
KBuckley is offline
Yanmar 2QM15 Overheating at Idle... backcreeksailor Gear & Maintenance 35 08-16-2012 10:58 AM
Yanmar SB 12 wont reach maximum RPM in neutral weststar Diesel 8 02-28-2010 06:22 PM
yanmar yse 8hp wont start warm andersj81 Diesel 9 07-30-2009 06:42 PM
Yanmar Idle doesn't return to low stop ereiss Gear & Maintenance 3 06-02-2009 05:20 PM
yanmar wont start((winterized)) codmander Gear & Maintenance 17 04-16-2009 07:14 PM
