Diesel won't start - SailNet Community
 2Likes
post #1 of 12 Old 05-21-2012 Thread Starter
leogallant's Avatar
Diesel won't start
Got a Vetus diesel on a Newport 30. Have waited too long since running it and now can't get it to start. We have bled the lines and fuel flows at all points. Neighbor thinks maybe its not drawing air, or perhaps does anyone think it might be something wrong with the injectors? Any help is much appreciated!
Leo
Journey to Charleston on Ubiquitous
Steve's Ubiquitous Blog
leogallant is offline
post #2 of 12 Old 05-21-2012
the pointy end is the bow
erps's Avatar
Re: Diesel won't start
Diesels need three things to run. Air, fuel and compression.
Are the batteries strong enough to turn the motor at regular starting speed? Does this motor have glow plugs? If so, check to make sure they're working, or that you're giving them enough time to warm up. When you say you have fuel at points, does this mean that you cracked the lines at the injectors to see if there was fuel there as well? Does the compression sound even when you're cranking it? I had a little westerbeke in a previous boat that one of the valves would stick open on it now and then and it was really obvious that there was no compression on one cylinder.
Injectors typically don't go bad just from sitting there and the engine just doesn't quit breathing air from sitting there either (unless a squirrel built a nest in the intake). Can't be much more help without more info on the symptoms.
Faster likes this.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #3 of 12 Old 05-22-2012
You say you waited too long. When did it run last and how/where was it stored? If you have confirmed fuel at the injectors, I would next suspect compression or glow plugs. Does the motor have decompression levers? Any chance they were left open when the boat was stored?
Jeanneau 54DS
Minnewaska is offline
post #4 of 12 Old 05-22-2012 Thread Starter
leogallant's Avatar
Diesel won't start
Yes, cracked open the lines all the way to and including the injectors and got fuel flow.
Was 2 months since starting, and it took about 15 mins of trying off and on to finally get ignition.
The batteries seem to crank it over just fine.
We recently replaced starter button, glow plug button, (last owner had disconnected) and kill switch button (which electrically pulls the button at engine to stop fuel flow).
Only thing we haven't checked is voltage at glow plugs which we'll do this weekend.
As far as compression, to the ear, it sounds the same as it always has. I don't believe we can operate one piston at a time on this unit.
I'll let you know what we find, hoping its the glow plugs and not a compression issue.
Leo
post #5 of 12 Old 05-22-2012 Thread Starter
leogallant's Avatar
No decompression levers that I know of. disregard my comment on operating one piston at a time :-)
Leo
post #6 of 12 Old 05-22-2012 Thread Starter
leogallant's Avatar
I am intrigued by this too and will double check the cranking as well. I just heard someone else mention cranking speed...
Leo
post #7 of 12 Old 05-22-2012
2 months is not a long hiatus for a diesel engine in good condition. Are you getting fuel out the exhaust pipe after prolonged attempts to start?.. if so that could mean low compression (which you can't really 'hear', btw)
Has it tried to fire at all, even a halfhearted 'thump'?
With all the changes you've made you may want to double check the wiring and the kill switch to be certain you're not trying to start with the switch/solenoid actually in the 'kill' position.
Also be sure to have your RW intake closed during these attempts or you might have bigger problems down the road... Open it again as soon as she fires but not before.
Faster is online now
post #8 of 12 Old 05-23-2012 Thread Starter
leogallant's Avatar
Yes, have double checked kill switch, and it's working correctly.
Why close the RW when initially starting? I think I've heard this before but can't remember why.
Will check to see if fuel is coming out exhaust pipe when cranking.
Thanks!
Leo
post #9 of 12 Old 05-23-2012
Thanks!
Closing is not necessary if you're confident that she will start. But if that doesn't happen then as you crank for extended periods you are pumping raw water thru the system and into the exhaust/muffler.
Without the pressure of the exhaust gases to expel that water it will backfill the system and eventually enter a cylinder thru an open valve - this can lead to "hydrolock" which can do serious damage and will appear as if the motor is seized.
post #10 of 12 Old 05-24-2012
erps's Avatar
We used to start old and cold diesel motors years ago with a shot of starting spray into the air intake. It's not my first choice, but if you're not finding the problem, it may just be enough to get a few coughs and sputters out of it until it can run on its own. There are some hazards with starting spray though. The urban myth is that too much can cause such violent ignition that it can bend connecting rods. I've never experienced this myself, but anytime anyone walked towards a duece and half truck with starting spray, some old Sgt. would remind them not to use too much.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
Diesel Engine won't start NCShadowdragn Gear & Maintenance 14 10-31-2016 05:59 PM
Volvo-Penta Diesel MD5A/110S - Cold Start/Stop Control jbdoucet Diesel 4 08-06-2014 08:47 AM
How to start diesel in spring davidpm Gear & Maintenance 24 05-05-2012 10:06 AM
Help. Diesel won't start. Air leak at filter? preservedkillick Diesel 14 06-08-2011 12:44 PM
Inboard automatic start up diesel generator evasion General Discussion (sailing related) 11 11-29-2010 08:21 AM
