Diesel/tranny et al mechanic suggestion in Charleston, SC? - SailNet Community
post #1 of 5 Old 05-24-2012 Thread Starter
Hello-
Starting to think we'll need some local help before trekking down the coast. Cannot track down a slow rattle in the drivetrain. Very certain it's not coming off the engine, chasing something at the shaft end of the tranny i think. Comes and goes, seems more prominent and lower RPMs and might be a sympathetic vibration? We're not on any schedule, but it's starting to look like we'll need some professional input. Mechanic recommendations would be much appreciated.
thx
CD28 is offline
post #2 of 5 Old 05-24-2012
Re: Diesel/tranny et al mechanic suggestion in Charleston, SC?
Contact Anthony Black at Marine Propulsion. He is based in Wadmalaw.
Ph (843) 559 1025.
Regards, Stanley
Stanley,
Marine Diesel Engine Vendor
NCboatrx is offline
post #3 of 5 Old 05-24-2012
You may be lucky. If it's a rattle in the drive disc and you can remove the transmission without removing the engine, replacing the drive disc is a relatively inexpensive. Of course, it'll be more expensive, if you have to remove the engine to remove the transmission ,and then reinstall and the transmission and engine and realign the engine after reinstallation.
Hudsonian is offline
post #4 of 5 Old 05-24-2012 Thread Starter
Thanks. Clearly I'm not a mechanic, nor do I play one on TV. Could you elaborate on other symptoms that I should expect or investigate- besides the aforementioned rattle? Many thanks!
CD28 is offline
post #5 of 5 Old 05-24-2012 Thread Starter
Thanks Stanley, ill chase them down tomorrow.
CD28 is offline
diesel mechanic needed.. groundhog Gear & Maintenance 21 09-04-2007 04:30 AM
Diesel Mechanic in NC mhfowle Gear & Maintenance 2 10-24-2006 08:24 PM
Diesel mechanic mrxonix Gear & Maintenance 0 10-24-2005 06:12 PM
need diesel mechanic in IL/IN elixir84 Gear & Maintenance 1 12-18-2001 08:41 AM
Need a Diesel Mechanic In Newport hamiam Gear & Maintenance 0 06-12-2001 12:25 PM
