replacement for Jabsco??? - SailNet Community
post #1 of 5 Old 05-26-2012 Thread Starter
I have an older Westerbeke 30 with a Jabsco 5320-0011 fresh water pump. The seal kit is on inter-gallatic back-back order, seals must be unobtainium or something. The impeller is a stock item.
A. Any one know if there is a replacement pump?
B How about another place for seals?
I understand Jabsco moved all these parts things to Mexico.
Just hoping someone out there has replaced with Johnson or something.
tomnarciso is offline
post #2 of 5 Old 05-26-2012
JimsCAL's Avatar
Re: replacement for Jabsco???
Is it belt drive or driven directly by the engine? If belt drive, a retrofit would be relatively easy. If not, have you contacted Westerbeke or MarineDieselDirect to see if there is a replacement pump?
JimsCAL is offline
post #3 of 5 Old 05-26-2012 Thread Starter
belt drive, I am looking at a Johnson pump but didn't now if any one had encountered this and could save me the machining. Thanks for the reply. I will try marine diesel.
post #4 of 5 Old 05-30-2012
I have new pumps and replacement parts for the Jabsco 5320-0011 give us a call. Depco Pump Company 800-446-1656
mariab is offline
post #5 of 5 Old 05-30-2012
Learning the HARD way...
eherlihy's Avatar
I was about to refer the OP to Depco Pump in Clearwater. Good people, great support!
Note mariab that you should have a signature that denotes your affiliation with Depco Pump... Otherwise, the mods may get cranky
eherlihy is offline
Easy Jabsco Head Replacement SVlagniappe Gear & Maintenance 4 06-27-2011 07:52 AM
waterpump replacement (jabsco) arne1981 Gear & Maintenance 2 04-26-2011 04:28 PM
Jabsco Macerator Pump aruggiero Gear & Maintenance 0 08-31-2009 01:56 PM
Brydon Par Jabsco svey Gear & Maintenance 2 07-22-2008 08:37 AM
Head Service Kit (Jabsco) offline2004 Gear & Maintenance 6 04-16-2007 11:39 AM
