1967 Volvo Penta? - Page 2 - SailNet Community
post #11 of 13 Old 06-11-2012
Irrationally Exuberant
Re: 1967 Volvo Penta?
Originally Posted by ACapri View Post
Just waiting on the batteries to finish charging
If those batteries, like the engine, have been sitting around for a few years, they probably aren't going to hold much of a charge now. Batteries generally don't tolerate sitting uncharged.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #12 of 13 Old 06-11-2012
Courtney the Dancer
jrd22's Avatar
More than likely that the engine will run just fine, those old Volvos seem to last forever. The transmissions also last a long time but sooner or later the clutch cone wears out and parts are not available any longer. My father replaced his 1970 Volvo for that reason, the engine ran fine but the trans. failed.
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
post #13 of 13 Old 06-11-2012
Old enough to know better
Originally Posted by misfits View Post
I'm not suggesting spraying WD40 as a starting aid, only a lubricating aid.
The motor hasn't been turned over for four years.
WD40 provides almost no lubrication, it is designed for displacing moisture. The WD means Water Displacement. I would certainly not want to rely on the extremely thin film WD40 leaves. I only use it as a cleaner. There are lots of good penetrating oils out there, WD40 is not one.
miatapaul is offline
volvo penta 90 sail smihal Gear & Maintenance 2 02-05-2011 10:30 PM
Volvo Penta opinions? birdlives Diesel 4 12-25-2010 06:40 AM
Volvo Penta 39 jernhenrik Gear & Maintenance 0 10-18-2009 12:00 PM
Volvo Penta MD2B OleCheers Gear & Maintenance 3 02-20-2009 09:04 PM
Volvo Penta engine rondezvous Gear & Maintenance 1 09-24-2006 12:24 PM
