VolvoPenta 2002 issues - SailNet Community
post #1 of 5 Old 05-31-2012 Thread Starter
As a new sailor and boat owner, docking has been the most anxious thing yet. Elite 32 with Volvo 2002 direct drive has been stalling when transitioning from forward and reverse; will always happen without fail during manuvering for docking.....not a good time or place for this. Any help in fixing this is appreciated; i have a good mechanical background, however am new to vovlo penta nomeclature.
Thank you all,
Dave
AKH20 is offline
post #2 of 5 Old 05-31-2012
Re: VolvoPenta 2002 issues
Maybe the idle speed is set too low? If it has a tach you could check it against the owner/shop manual. You might try disconnecting the control cables and test it at the dock. Does it run OK at speed under load?
Paul T
dabnis is offline
post #3 of 5 Old 06-11-2012
PhilipStevens's Avatar
Send a message via Skype™ to PhilipStevens
Thank you all,
Dave
Download all the manuals you need from here
I have the 2003 in our boat, and I would say, as the previous reply, that it is your idle speed that needs increasing.
The owners manual give idle speed as 850rpm, with max output revs at 3200rpm. Check it with a/your tacho.
regards,
Philip.
PhilipStevens is offline
post #4 of 5 Old 06-11-2012 Thread Starter
Thank you for the replies !!!
I have not been able to get to boat since last post, however; the engine seems to run fine in all other operation except for transition from forward to reverse or vise versa. There is a slight vibration though; i have not checked alignment yet. In regard to idle; i am going to assume that is to set in nuetral, yes? I am begining to wondering about engine control cable hystersis; when i set the idle higher when last at boat, it was not the same when cycled through range.
Thanks you for all the help :-)
Dave
AKH20 is offline
post #5 of 5 Old 06-11-2012
Suggest you warm up the engine, disconnect the cables and set the idle to whatever is specified in the manual with the gearbox in neutral. Re-connect the cables and cycle through forward, neutral, and reverse. If there is any change in RPM the cable tension may need to be adjusted or the cable may need to be lubed.
Paul T
dabnis is offline
Volvo 2002 injector GerryC Diesel 3 12-20-2010 05:26 PM
2002 J/80 for sale on EBay CharlestonBW Boat Review and Purchase Forum 2 11-08-2002 06:17 AM
2002 J/80 for sale on EBay CharlestonBW Racing 0 11-07-2002 05:57 AM
Around Alone 2002-03 Preview Brian Hancock Racing Articles 0 09-11-2002 08:00 PM
IMTS 2002 Denr General Discussion (sailing related) 0 08-25-2002 11:43 AM
