Seeking rebuilt Universal M25X engine - Page 2 - SailNet Community
post #11 of 18 Old 06-08-2012
Re: Seeking rebuilt Universal M25X engine
Contact Ken Roy at Catalina Yachts. I believe they still have several brand new MX-25's they are trying to get rid of. I'm not sure if they are Xp's or XpB's
Antony Dalton
Tampa Bay, FL
1994 Catalina 30 MKIII "Bliss"
AV8RSailor is offline
post #12 of 18 Old 06-08-2012
Stu Jackson's Avatar
Originally Posted by George6 View Post
hey, Jim. My Newport had the same model. The post from gmackey is what I did. The only thing is the oil dip stick is on the left. The D950 model is correct if you want to change it out. Same engine all the way around. Bolts right in. cheaper than the marinized version.
The oil dip stick IS on the port side on Kubota engines. That hole was simply plugged and the port side standard dipstick installed on the boat engines. A friend of mine bought a used M25 (same as the XP except for a few details and a D850 block) and considered using the port side for his Pearson 30-something.
The marinized version only adds the HX - not a big deal
Buy Kubota, save mucho $$.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #13 of 18 Old 06-09-2012
souljour2000's Avatar
I have a M25Xp in my C-40...a bit underpowered for an 18,200 lb boat but not a bad tradeoff since it's a Kubota tractor engine and parts are very easy to find...the motor was installed in 1988...probably 500 hours...need to find 3 new injectors for her...has a new injector pump... everything else just needs cleaned up...new fuel filters...slap in the injectors and hopefully she will be okay...not that simple sounding but something like that...got plenty of manuals/ info about the engine came with the boat... we'll see how it goes soon enough
Columbia 40
souljour2000 is offline
post #14 of 18 Old 06-09-2012 Thread Starter
My engine has been having issues for three seasons. Started with raw water pump going bad, mechanic said it could not be fixed. Called Catalina they thought that sounded odd, but three mechanics laters, it cant' be fixed. Cam shaft stuck, does not turn?? We put on a little electric pump for temporary solution while we figured out what else to do. In the meantime, fuel injector got stuck, had that rebuilt, then after all of this, she still has issues. Started her up this year and she just sputters. Failed three compression tests. Boat is in Oxford. Seems cost of getting engine rebuilt is similar to buying a rebuilt engine (but they want my core in exchange as part of deal). Will look into the Kubotas mentioned and also the crated new Catalinas. If the new one is M25-XPB is that a good choice?
sailthebay7 is offline
post #15 of 18 Old 06-09-2012 Thread Starter
I need to see exactly what we have, if it's an XP or an XPB. It rattles like crazy so maybe it is the "B" version.... need to verify.
post #16 of 18 Old 06-10-2012
creedence623's Avatar
Contact Al at Schooner Bay Marina at 715-779-5849. He rebuilds Universals. I did a 1 for 1 swap with my M-25XP from my old Catalina 36. Price at the time was $4900 which included shipping, and they knock $1000 off that if you send the orignal back to them (they pay shipping for that).
I could not have been happier with the engine, ran like new, looked new, literally NO issues with it at all; and the rarest gem of all (apparently) in the marine industry, great and proactive communication on their part. If there are delays, he will contact you in advance to keep you up to date.
(No affiliation, just very happy with the customer service and quality of work)
S/V FREEDOM
2002 Beneteau 393
I'm a sailor, I sail!
creedence623 is offline
post #17 of 18 Old 06-10-2012 Thread Starter
Thanks creedence! I have talked with Al, right now he is a very good option on a rebuilt. Exploring a few other options posted here, but I really appreciate your great comments on Al's work. He seems like a good bet when I spoke to him about his process, etc.
Thanks so much for the candid comments!
post #18 of 18 Old 06-10-2012
Did you read my first reply? M25XPB, B means don't bother. Folks with C36s who have them report they rattle like crazy and can't find an idle speed less than 1400 rpm. Don't go there. Please.
See no reason you can't fix yours without having to replace. Low compression? Replace the rings. Did you read the Rebuild link I provided.
Good luck.
Tags
catalina 28 , engine , rebuilt , universal
looking for universal m-18 engine jollyrogersc Diesel 7 12-11-2013 01:44 PM
Universal Diesel M25X overheating glassdad General Discussion (sailing related) 6 12-15-2011 12:41 PM
Rebuilt engine = good thing? zAr Boat Review and Purchase Forum 7 06-01-2009 07:31 PM
Universal M-25 engine Gary1 Gear & Maintenance 11 07-15-2008 09:22 AM
Universal M12 Engine bushrat Gear & Maintenance 0 10-02-2007 09:11 PM
