Yanmar 2QM15/primary fuel filter - SailNet Community
 1Likes
  • 1 Post By RichH
post #1 of 2 Old 06-04-2012 Thread Starter
so I just bought this boat. When i went to change fuel filters, oil, and filter i found there was not a primary/water seperator filter. the only filter is the secondary on the engine. the boat is a 78 model and has probally been this way for a while. do you think i shlould add one or since it isnt broke dont fix it?
tom
rox33861 is offline
post #2 of 2 Old 06-04-2012
RichH's Avatar
Re: Yanmar 2QM15/primary fuel filter
The 2QM and 3QM engines were supplied with an engine mounted 'guard' filter at 15-17然 'nominal' retention 'rating'. The 'guard filter' is the teeny filter that is mounted ON the engine; the only purpose of the 'guard' is to protect the engine fuel pumps IF any upstream filter fails.
For 'best' protection, there should be a 10然 (Racor, etc. type) filter that precedes the engine guard. If your fuel tankage is notorious for historically releasing 'slugs' of debris or you get your fuel from 'notoriously' dirty fuel depots (ie.: marinas), then the 10然 should be preceded by a 30然 nominal rated Racor type filter.
Simple Speak: put a 10然 'upstream' of the engine mounted 15然, if the 10然 plugs rapidly then put a 30然 upstream of the 10然 and/or clean out the tank.
Tank ---> 30然 (optional) ---> 10然 ----> 15-17然 (engine 'guard') ---> engine.
jppp likes this.
RichH is offline
Yanmar 3GMF primary fuel filter change dfsdghsdhsd Diesel 10 05-01-2016 09:45 PM
Primary fuel filter Jotun Gear & Maintenance 30 12-19-2010 02:01 PM
Clogged Primary fuel filter. L124C Diesel 12 12-19-2010 12:42 PM
Yanmar 3GM30F Primary fuel filter thaeni Diesel 3 08-10-2010 12:00 PM
Yanmar 2QM15 - Changing the Fuel Filter backcreeksailor Gear & Maintenance 15 06-04-2009 07:36 PM
