Yanmar 2GM20 steam through the Exhaust - SailNet Community
post #1 of 8 Old 06-06-2012 Thread Starter
Help.
I have a Yanmar 2GM20 that when not in gear and high revs the exhaust is normal. As soon as the gear engages steam comes out of the exhaust.
I have checked the water pump and engine for blockages, there are none.
Has anybody got any ideas...??
trendyp is offline
post #2 of 8 Old 06-06-2012
Oaksail's Avatar
Steam in the exhaust indicates water or coolant from the cooling passages is getting into the combustion chambers
1989 CS30
Oaksail is offline
post #3 of 8 Old 06-06-2012
Seņor Member
PorFin's Avatar
Re: Yanmar 2GM20 steam through the Exhaust
If you're lucky, it's just a leaking head gasket. Try torquing your head bolts back down to see if that solves the issue. Hopefully, it will.
If not, then you need to rule out the other possibilities (e.g., warped head, cracked head, cracked block, etc.)
PorFin is offline
post #4 of 8 Old 06-06-2012
Is it steam or white smoke?.. There is a difference. Steam indicates overly warm raw water, actual white smoke is usually coolant being burned. Is your mixing elbow in good shape?
Faster is online now
post #5 of 8 Old 06-07-2012
Dirt Free
boatpoker's Avatar
Look at your oil and coolant for contamination, water in the oil or oil in your coolant and you've got a problem.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
post #6 of 8 Old 06-08-2012 Thread Starter
Thanks for the advice. I tried torqueing the cylinder head bolts and they were tight so I took off the head to have it tested. The head and gasket looked ok to me, although I don't really know what I'm lookig for. I also took out the injectors and injector pump to have them tested. Hope i've covered averything.
trendyp is offline
post #7 of 8 Old 06-09-2012
Senior in age only!!!
centaursailor's Avatar
Recently had the same problem after fitting a new replacement impeller in the cooling water pump. Spitting water but lots of steam. Put back the old one and everything back to normal. Maybe yours is worn.
Safe sailing
The great appear great because you are on your knees. James Larkin, Irish Labour Movement.
centaursailor is offline
post #8 of 8 Old 06-09-2012
Senior Slacker
SlowButSteady's Avatar
Could be an almost clogged water injector in the mixing elbow -- there isn't enough water flowing through the system to keep the elbow cool, hence the steam. Take the mixing elbow off and see how much crap has built up inside. Also, try blowing into the nipple where the water hose connects to the elbow; if you get any back pressure then it's probably time for a new elbow.
Never forget them. Do something to prevent it from happening again.
Charlotte Bacon, Daniel Barden, Rachel Davino, Olivia Josephine Gay, Ana M. Marquez-Greene, Dylan Hockley, Dawn Hochsprung, Madeleine F. Hsu, Catherine V. Hubbard, Chase Kowalski, Jesse Lewis, James Mattioli , Grace McDonnell, Anne Marie Murphy, Emilie Parker, Jack Pinto, Noah Pozner, Caroline Previdi, Jessica Rekos, Avielle Richman, Lauren Rousseau, Mary Sherlach, Victoria Soto, Benjamin Wheeler, Allison N. Wyatt
SlowButSteady is offline
Yanmar 2GM20 vs 2GM20(f) (What the F?) L124C Diesel 11 06-17-2011 04:08 PM
Help regarding steam or smoke coming from an exhaust component, time sensitive.. chrisncate General Discussion (sailing related) 27 02-17-2011 10:41 PM
Yanmar YSM 12 Vs. 2GM20 Medusa28 Diesel 2 11-08-2010 12:20 PM
Yanmar 2GM20 F Exhaust Riser bolt Torque specs ronsunni Diesel 0 10-08-2009 01:59 PM
Exhaust Steam Sixbrothers Diesel 3 09-06-2009 05:19 PM
