volvo penta md2010 won't start - Page 2 - SailNet Community
post #11 of 18 Old 07-26-2012 Thread Starter
Re: volvo penta md2010 won't start
birdlives,
thanks for the ideas. I have not found the problem. At first I thought it was a bad connection at the solenoid. Once I cleaned that up engine worked fine. Then a few days later, stopped working. I recleaned the solenoid connection and it worked again. Then a few days later stopped working. This time cleaning the connection did'nt work. I then went into the lazarette to follow the wiring back to the switch. This boat has a harness from engine to switch, so no loose wires. Everything looked fine. I checked to make sure everything was snug at switch end and that the 16 prong plug was connected firmly, which it was. Then the engine starts?? The engine has now worked several times in a row. What troubles me is there was nothing apparently loose in the wiring. The wires for the ignition swith come right out of the plastic back of the switch and go into the harness. The plug on the harness is like you find on cars where it snaps together. I should also state that this was a fresh water boat for the last 5 years (but is now in salt water for 6 months) there is no corrosion anywhere.
I'm glad engine seems to be working, but I would feel better if I knew I had actually fixed something. Every time I turn the switch I wonder if it will start.
tahoemark is offline
post #12 of 18 Old 07-26-2012
I have been having a similar problem, have the same type Volvo harness. The engine starts fine at the dock, runs for an hour or two. Then I turn it off and sail for three hours or less and cannot restart. The next day at the dock the engine starts fine again and later in the day (when warm) it will not.
I checked the leads on the key switch, the relays, the harness, all seem good. It appears to be a connection that when it gets hot expands or something and then does not work..it is driving me nuts.
I even had a Volvo factory mechanic out and he said to find the problem would be absurdly expensive, might take hours.
My solution (and its not a great one) was to do two things. We wired a seperate set of wires from the key switch to the starter (kind of paralleling the Volvo setup) and also installed an on off switch that was essentially a jumper from the the battery direct to the starter. I lose my instrumentation but do not have to be towed ignominiously back to the dock.
Still have no answer to the problem, its a Volvo thing.
birdlives is offline
post #13 of 18 Old 07-26-2012 Thread Starter
Ron,
Thanks. I'm glad to know someone else had the same problem, I thought I was going nuts. I'd like your help in telling me how you did the separate key to the starter. On the engine end the harness comes up into the relay box, so I can't see how you could wire it there. Did you just wire it to the solenoid? If so that obviously takes the glow plug out of the loop, but I suppose you could just crank for 10seconds or so and it would start. Do I have this right.
Mark
post #14 of 18 Old 07-26-2012 Thread Starter
Ron,
I tried to PM you, but I don't have enough posts. I imagine I can reply to your pm if you would like my email and we can correspond directly. Curious, what boat do you have??
Mark
post #15 of 18 Old 07-26-2012
Tahoe,
As Bird said, just by-pass the original wiring. If that works there is an intermittent problem somewhere in the harness that you may never find.
Paul T in Truckee
dabnis is offline
post #16 of 18 Old 07-27-2012 Thread Starter
thanks Paul in Truckee. I lived over by Cave Rock for 15 years, now in So CAL. Anyway, wiring harness conveniently plugs into to the bottom of a relay box at the engine end, so not so easy to just run another wire. Wiring harnesses are great...until they fail!
post #17 of 18 Old 07-27-2012
If you have a solonoid between your start key and battery source and it works, it would appear the wire from the start key to the solonoid may be bad. What I had in mind was temporarily running a seperate wire from the solonoid to a seperate switch to battery source to see if that works? If you have Battery from the starting key going directly to the starter, that is a heavy load to be going through a starter switch and the key switch may have bad contacts? You could jump directly from the battery to the starter post in an emergency.
A diagram of your starting system would help.
Paul T
dabnis is offline
post #18 of 18 Old 08-03-2012
I agree with c-wolf's diagnosis, but would add that you might check the connectivity of the ground running from the starter to the engine block, most likely. Remove and inspect the ground terminal, and sand the ngine block where it connects. This may not be the cause, but could be part of the problem.
Sabre Dan is offline
Volvo-Penta Diesel MD5A/110S - Cold Start/Stop Control jbdoucet Diesel 4 08-06-2014 08:47 AM
Volvo MD2010 won't bleed talbot Diesel 5 08-10-2011 01:38 PM
volvo penta 90 sail smihal Gear & Maintenance 2 02-05-2011 10:30 PM
Volvo Penta opinions? birdlives Diesel 4 12-25-2010 06:40 AM
Volvo Penta 39 jernhenrik Gear & Maintenance 0 10-18-2009 12:00 PM
