How to Remove Diesel from Tank? - SailNet Community
 1Likes
post #1 of 20 Old 06-20-2012 Thread Starter
SailAway
maccauley123's Avatar
To prevent any fuel problems I am going to remove the diesel fuel from my tank and replace it with fresh. It is only 12 gallons so is not that much. How do I get the fuel out? What kind of pump should I use? A friend tried to use a manual style pump and it didn't work. Just made a mess. We both tried using a drill driven pump and it wouldn't work. It doesn't have enough lift to pull the fuel up the 3-4 feet from the tank through the fill hole into 5 gallon containers. Is there a small, simple, portable pump I can use that will have enough lift?
You will regret the things you did not do, more than the things you did.
Get out there!
Saco Bay, Maine
2001 Beneteau Oceanis 361
maccauley123 is offline
post #2 of 20 Old 06-20-2012
Re: How to Remove Diesel from Tank?
I always try to siphon fuel if I can. There is a device called a simple siphon which makes it really easy to start although I haven't tried it with a big head. Alternatively, if you use flexible tubing you can shove a bunch in the tank, pinch the tube off and pull it out. As long as you have enough tube with fuel in it to get below the level of the tank, you can un-pinch it and it will siphon. All of this is harder if your boat is in the water already since it is hard to get jerry cans below the tank level.
klem is offline
post #3 of 20 Old 06-20-2012
Use a vacuum oil changer reservoir and transfer the fuel to jerry cans.
Faster is offline
post #4 of 20 Old 06-20-2012
One of None
deniseO30's Avatar
siphon is great and cheap if the tank is higher then the receiving container.
to pump, you need a self priming impeller pump. most drill pumps aren't worth the $ A 12 or 120 volt flotech pump should do the job. Hand held plunger pumps work pretty well too.
My last project!
deniseO30 is offline
post #5 of 20 Old 06-20-2012
peikenberry's Avatar
Some diesel tanks have a drain on the bottom of the tank.
Ike
My Boat building Web Site
My Boating Safety Blog
Dont Tell Me that I can't. Tell me how I can!
peikenberry is offline
post #6 of 20 Old 06-21-2012
Irrationally Exuberant
Does your tank have an inspection port or a gauge on it? I'd pump from there rather than from the filler hole up on deck. Just lay down plastic and something absorbent to avoid the dreaded diesel in the cabin.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #7 of 20 Old 06-21-2012
Wish I never found SN!
SimonV's Avatar
cheap 12 volt fuel pump, about $30 and keep it as a spare.
sawingknots likes this.
Simon
I miss my boat
Brisbane
DELIVERY SKIPPER
Drinking Rum before 10am makes you a Pirate NOT an alcoholic
SimonV is offline
post #8 of 20 Old 06-21-2012
First, invert the boat.
Oh. Sucking the fuel all the way up the filler hose may be impossible. I also second the vacuum oil pump as being one of the best ways to suck stuff up, and you'd use it in the top of the diesel tank. There's either going to be an inspection plate, or a collar that allows the fuel gauge to be removed, accessing it from there.
A drain valve on a marine diesel tank is unlikely, on small craft apparently that's either an ABYC or USCG no-no.
You could also pick up a cheap fuel pump (as I understand it, a gasoline pump will work) and hook it up to the fuel feed on the tank, and just pump it out that way.
But if you are going to the trouble of cleaning out the tank, REALLY consider going the whole nine yards. Remove the tank, get back in there to clean and inspect, and while the tank is out have it steamed out to get rid of any crud, if you can find a radiator or tank shop that will do it for you.
Changing out old fuel, that's nice. But if there's crud in the fuel, odds are there's biomatter on the tank interior as well, and if you clean it out now you can make sure it doesn't come back.
hellosailor is offline
post #9 of 20 Old 06-21-2012
RichH's Avatar
If the tank is not in the bilge but slightly higher in elevation, then the easiest/cheapest way is to simply siphon the fuel into a 'lower' container.
RichH is offline
post #10 of 20 Old 06-21-2012
casey1999's Avatar
Originally Posted by maccauley123 View Post
A friend tried to use a manual style pump and it didn't work. Just made a mess. We both tried using a drill driven pump and it wouldn't work. Is there a small, simple, portable pump I can use that will have enough lift?
Electric drill pumps are not for diesel. The sparaks from drill brushes could ignite fuel.
Maybe try:
Diesel Transfer Pump - Save on this 12 Volt Transfer Pump
or
12 Volt Electric DIESEL Fuel Transfer Pump 4-7psi 35GPH - JTOutfitters
Check how much lift you need (how high from bottom of tank to receiving tank). 1 foot height = about 0.5 psi.
casey1999 is offline
Cleaning Out a Diesel Tank Allanbc Gear & Maintenance 51 07-21-2012 09:42 PM
Remove/replace water tank - Islander 37 island37 Gear & Maintenance 7 04-17-2011 12:11 PM
Tank remove/replace deniseO30 O'Day 47 02-21-2011 11:48 AM
Converting water tank to diesel tank - fittings? Zanshin Gear & Maintenance 5 09-15-2009 05:38 AM
Dirty fuel, cannot remove tank 82sabre Gear & Maintenance 9 06-15-2008 07:09 PM
