Yanmar YSE8 no secondary filter - 2 micron racor in primary? - SailNet Community
Advertise Here
Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Engines > Diesel
Diesel This is a new forum dedicated to diesel engines and their applicable accessories.
Old 06-23-2012
OneidaLakeSailor is on a distinguished road
Still learning my boat.
Doing the diesel maintenance on my YSE8 for the early part of the season here in NY. Going thru checklist in Yanmar manual, and in the Don Casey Sailboat maintenance book.
Trying to inspect or replace secondary filter.
Only to find that it has no secondary filter.
Should I replace the primary Racor R12P 30 micron filter with a 2 micron filter and then watch it carefully....?
Or should I try to purchase and install an in-line secondary?
Thanks,
A
  #2
Old 06-23-2012
Irrationally Exuberant
arf145 is on a distinguished road
Re: Yanmar YSE8 no secondary filter - 2 micron racor in primary?
So, if what I've read is correct, the YSE8 didn't have a secondary on the engine itself, but it was mounted on a bulkhead in some cases. Have you traced the fuel line all the way from the primary to the engine to make sure there isn't one somewhere along the way? Probably you have, but just checking. Don't know what kind of fuel pump you've got, but 2 microns is a pretty small straw to be sucking through for the diaphragm types.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
You may post attachments
You may edit your posts
Yanmar 2QM15/primary fuel filter rox33861 Diesel 1 06-04-2012 04:23 PM
Replacing secondary filter on Yanmar 1GM10 diesel dgililov Gear & Maintenance 3 02-09-2012 11:54 AM
Primary and Secondary fuel filter question dhays Diesel 8 08-05-2011 08:43 PM
Yanmar 3GM30F Primary fuel filter thaeni Diesel 3 08-10-2010 12:00 PM
RACOR Primary Filter Element KindOfBlue Gear & Maintenance 10 07-05-2008 09:02 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
